Best INTERCOOLERS - PLUG & PLAY
Old Aug 12, 2009 | 01:50 PM
  #31
vividracing's Avatar
The specs on our intercoolers are:
-Core Thickness: 3.5 inch
-Core Volume vs. Stock: 40% larger
-Performance Efficiency: 85%
-Flow rate: 620 CFM / side
-Leak Tested: @ 30 PSI
-Pressure Drop: less than 1%
-Support HP: 750+
Get pictures of the others installed, if the core is thicker, you cannot clip OEM plastic shroud in place, it wont reach.
Old Aug 12, 2009 | 02:45 PM
  #32
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Originally Posted by RichardCH
So Dan how Thick/Deep are yours vs OEM please ? If AWE & Evoms are genuinely plug and play, yours must be significantly different no ???
The EVOMS units are truly plug and play. Here's a couple more pics, one mounted, and one to show the difference from stock vs the EVOMS units.
Old Aug 12, 2009 | 02:52 PM
  #33
Tom that does not answer Richard CH question. Show a picture without the bumper. For the intercoolers to be mounted with the factory ducting, does it retain the factory clip to connect the piece together or is that modified.
Old Aug 12, 2009 | 03:21 PM
  #34
Correct, I'm looking for pics without the bumper. But yes, the factory piece needs to be slightly modified to accommodate the larger cores.
Old Aug 12, 2009 | 03:24 PM
  #35
Cool deal. RichardCH, there you have it, all aftermarket intercoolers must modify the plastic housing to fit. Big difference between the Agency Power and EVOMS is their intercoolers DO NOT use the factory style boost hoses. So when you buy their intercoolers, you will spend another $1000 on boost hoses. Our intercoolers fit the OEM hoses, Samco, or Agency Power units.
Old Aug 12, 2009 | 04:11 PM
  #36
unvmy996's Avatar
there is no such thing as plug and play.... the plastic housing MUST be modified inorder for the biger cores to fit.
Old Aug 12, 2009 | 04:37 PM
  #37
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
Essentially, but it all depends on your power goals, as in, do you need a bigger core? What will you be doing with the car? Etc...
Old Aug 12, 2009 | 04:40 PM
  #38
unvmy996's Avatar
whats the use of getting new coolers if your not increasing the core size ? i mean even if you do a bar and plate.
Old Aug 12, 2009 | 05:12 PM
  #39
997FL's Avatar
997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !997FL Is a GOD !
That is 100% correct
Very valid point and thank you for your input.
Old Aug 12, 2009 | 06:15 PM
  #40
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
The Evoms units were tested on this car in a race environment and at 1037awhp....Check the vids .....atleast you know you won't need to buy intercoolers until 1050awhp or more.
http://www.youtube.com/watch?v=-0P6VDQ1YDs
http://www.youtube.com/watch?v=RXfPE8rv_Gk
Old Aug 12, 2009 | 06:34 PM
  #41
Tym's are designed from the very ones he developed for the Sledgehammer - 1000hp.
Old Aug 14, 2009 | 12:08 PM
  #42
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Dan, I appreciate you clarifying that for me, this is all very interesting, so in all cases with Evoms & AWE I would additionally need the expensive new Hoses, I don't see any real need for them below 600 BHP ?? I may change the Intake Plenum at my next major service but stay with 70MM
Old Aug 14, 2009 | 12:13 PM
  #43
Richard - dont waste your money on the plenum. You would actually get better results from the intercoolers. PM me your mods so I can give you some recommendations.
Old Aug 14, 2009 | 11:29 PM
  #44
RCH's Avatar
RCH
Dan, engine wise I have; Upsolute stage 2 ECU tune, DV's, Waste Gate Actuators, Sports Exhaust with 100 cell race cats, BMC air filter. In Europe on 98 Gas I see 1.3 Bar everyday !
Old Aug 15, 2009 | 12:07 AM
  #45
Zippy's Avatar
Originally Posted by evo911
here is the Switzer core on my car. 6"!
Cool!
