HELP. Shifter problem
Old Aug 18, 2009 | 07:40 AM
cab2u's Avatar
cab2u is infamous around these parts
Just put my 03 turbo into first gear, seemed to go in hard and travel further than normal. Now stuck in first. Shifter flops back and forth. Does not seem to be connected to anything.
Just researched and found that some plastic piece broke. Are there instructions anywhere on how to replace? Also, what is the part number?
Old Aug 18, 2009 | 07:50 AM
ttboost's Avatar
Pop the shifter boot/cover off. Your cable(s) likely came undone. I think you need an allen wrench to fix it. Make sure the shifter handle is in a perfectly vertical position or your linkage will be off a little.
Old Aug 18, 2009 | 08:11 AM
DMaffo's Avatar
DMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud ofDMaffo has much to be proud of
to get to it properly you ahve to take it all apart. Very easy but there are some hidden plastic covers for some of the screws for the arm rest and such. Ill have to look for link but trust me in 10 min you are done!!
and ttboost is right. It may very well be a clip or something that came off. I played with my shifter so it shifted into 1st closer to my leg so that 5th wasnt so far away. If you are slightly mechanically inclined you will figure it all out.
2 flaps on side of radio console come off, the the arm rest and everything else you just figure out.
Old Aug 18, 2009 | 08:25 AM
DMaffo's Avatar
www.bmracing.com/bmracing/installation_instruction/67.pdf
click on that link to give you some guidelines. Its all the same practically. Once in ther eyou can figure it out. If you dont mark the cables then it will be off to the right or left. I found out by accident but then I tinkered around with it till i found a place where I like my arm to reach for all gears...!
Old Aug 18, 2009 | 08:26 AM
cab2u's Avatar
I can see that the cable is not connected to the bottom of the shifter. Are there going to be any broken pieces? Can I just put it back on after I take the car apart?
Old Aug 18, 2009 | 08:28 AM
ttboost's Avatar
Yup, just slide it back in and make sure it is TIGHT! You might be able to slide your hand under the passenger side of the console and sneak it in. I've had to do some roadside surgery as this happened to a friends car...
Old Aug 18, 2009 | 08:42 AM
DMaffo's Avatar
pretty soon you will be able to tackle almost anything on the car without fear. I let a freidn borrow my car and he came back with a flatbed and my car on it!! broken shifter, literally.... i changed in my undergournd!! play aournd with it..make sure its sucure and tight as ttboost said.!
Old Aug 18, 2009 | 09:03 AM
cab2u's Avatar
OK, I took off the center console. The black plastic piece with the socket for the bottom of the shifter came off. There are 4 white plastic arms in the socket. One of the them is broken. What do I need to replace? Part numbers?
Just spoke to a mechanic at Manhattan Motorcars. He told me that I need to replace the black piece, and that he will lend me his special tool needed to replace it, and that he will have them ready for me to pick up. How cool is that.
(Do I really need the tool or can I do it without it. Kind of a pain the butt to bring the tool back to him)
Old Aug 18, 2009 | 09:27 AM
DMaffo's Avatar
did you open link I sent you?
Old Aug 18, 2009 | 09:49 AM
cab2u's Avatar
Yes. I used the instructions to take everything apart. I am going to pick up the part from porsche. I just cannot wait to get evoms part. I need to fix the car today. I just wanted to know if I really needed the special tool to remove and replace the part.
Old Aug 18, 2009 | 11:23 AM
DMaffo's Avatar
cant remember using any special tools... hmmm....
Old Aug 18, 2009 | 11:27 AM
ttboost's Avatar
No tools either, but I never broke the little plastic wings that attach to the springy thing...??? I thought they just pop off or thread off?
Old Aug 18, 2009 | 12:47 PM
cab2u's Avatar
Borrowed the tool. It is a plastic thing that clips onto the shift **** and centers the stick. Probably not necessary but didn't have to deal with making sure the stick was centered in neutral.
$20.05, 40 minutes total work (not including over an hour to get to and from dealer. Manhattan subway), and car is fixed.
Thanks for everyone's help.
Old Aug 18, 2009 | 12:53 PM
DMaffo's Avatar
thats what I was missing then!! ll...my shifter wasnt aligned but then I started messing with it and I found out how to align it to what I like!
So glad you got it going!!!
ttboost's Avatar
That's the tool I thought you were talking about. When I bought my 997 shifter, it came with one. Mine was green, but I've seen them blue too...
Glad your up and going...
Kai@ELITEMS
996 Turbo Vendor Classifieds
Nov 25, 2015 06:44 AM
Kai@ELITEMS
Nov 25, 2015 06:40 AM
Kai@ELITEMS
997 Turbo Vendor Classifieds
Nov 25, 2015 06:39 AM
Kai@ELITEMS
996 Vendor Classifieds
Nov 25, 2015 06:32 AM
Kai@ELITEMS
997 Vendor Classifieds
