psm won't turn off on 996TT, why??
Old Aug 30, 2009 | 10:40 AM
xico's Avatar
Exotic Performance
xico is infamous around these parts
the pm system in the car won't turn off, does any one know what to do to correct this problem
Old Aug 30, 2009 | 12:16 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
try unhooking you batt for 15min that will reset everything, be sure to have your radio code
Old Aug 30, 2009 | 03:14 PM
xico's Avatar
Exotic Performance
thank you, i will try it to see if it works
Old Aug 30, 2009 | 05:27 PM
ExclusiveTT's Avatar
ExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond repute
depends on what you mean by OFF.. is the PSM light on and wont turn off, or you cannot deactivate PSM (turn light on)?
Old Aug 30, 2009 | 06:54 PM
ABCar's Avatar
ABCar is infamous around these parts
Try holding the button in for 15 sec...(worked on another car I had)
Old Aug 30, 2009 | 07:44 PM
xico's Avatar
Exotic Performance
Thank you guys, i tried disconnecting the battery for 30 minutes and pushing the button to turn the psm of , but neither will work.
Old Aug 30, 2009 | 07:49 PM
xico's Avatar
Exotic Performance
we are trying to deactivate the psm . the car is trying to correct itself at over 100mph in third gear, is trying to break lose. it has a lot of torque and the psm does not know what to do. i read the code and it comes up as a torque correction fault
Old Aug 30, 2009 | 11:11 PM
Turbo Fanatic's Avatar
The PSM should turn off wen you press the button (you'll see an orange warning lamp in the dash).
When working properly that will defeat stability management 100% but will turn it on temporarily when you step on the brakes.
Old Aug 31, 2009 | 03:50 AM
xico's Avatar
Exotic Performance
that is what we want to accomplish
Old Aug 31, 2009 | 05:26 AM
RDH's Avatar
RDH
RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !RDH Is a GOD !
xico.....havent seen you here in these parts for ages.....Hope all is well with you and the family down there...
NC 996TT
Mar 23, 2023 06:19 AM
Feelgood MD
Mar 24, 2016 09:35 AM
BLKMGK
Sep 19, 2015 03:51 PM
Korntera
Sep 15, 2015 08:20 PM
katyrow
Sep 7, 2015 10:17 AM
