Straight pipe 996 turbo? Anybody try?
Old Feb 15, 2010 | 10:20 AM
  #61
Prche951's Avatar
Originally Posted by heavychevy
Hmmm, I don't know about that one, I've heard some NA 911's at Club Races that will pierce your eardrums from 50 yds away. Turbo may be louder at idle, but as soon as you hit WOT, the brain scrambling begins. Might as well have your head at the tip of the exhuast pipe with the NA cars.
exactly...painful NA cars with straight pipes.
Old Feb 17, 2010 | 08:32 PM
  #62
WOODTSTER's Avatar
Originally Posted by Al Norton
They are pretty loud; especially if you have larger turbos and are pushing more air though the engine. Mine are so loud at WOT that I wear ear plugs at the track. I think the ECU may need modification for the after-cat sensors but not sure.
Hey Al,
Is Neil Orton still alive ??
Old Feb 17, 2010 | 08:33 PM
  #63
WOODTSTER's Avatar
I agree,
They sound like an obnoxious motorboat; Awful sound.
You can get plenty of power thru a good exhuast;
Ie Switzer, SpeedTech, EP Loud
Old Feb 17, 2010 | 08:43 PM
  #64
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
Woodster, were you at a F-1 or a Indy car race in your Avatar pic?
Old Feb 17, 2010 | 08:58 PM
  #65
Almo's Avatar
Almo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant futureAlmo has a brilliant future
Seeing this thread has me wondering... anyone know of a person that has cut the stock exhaust?
Asking because this is what I'm doing this week. Will be dropping the ends by the welder sometime this week. I have a feeling, especially looking at the flap coming off the cat inside the shell... it looks like it will reflect the dispensed exhaust against the apposite side before exiting thought the tailpipes. This should cut down on the baffle sound a muffler bypass gives off and even give this little setup some back pressure.
https://www.6speedonline.com/forums/...sche-week.html
Old Feb 18, 2010 | 01:02 AM
  #66
iLLM3's Avatar
I'm comparing a fabspeed muffler/cat bypass setup on a 996 gt3 vs my car with fvd straight pipes off the turbo... I wasn't speaking for the masses , way too many different setups and cars out there!
Old Feb 18, 2010 | 06:05 AM
  #67
Sawsall RULE! Nice pics and very telling to why Stock Sucks!
Old Feb 18, 2010 | 07:47 AM
  #68
rickabeir's Avatar
rickabeir is infamous around these parts
They work well
Old Feb 18, 2010 | 08:18 AM
  #69
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
Originally Posted by iLLM3
I had NA cars with straight pipes, you are right, but have you ever heard a TURBO WITH STRAIGHTS< next to a GT3 WITH STRAIGHTS?! You would be shocked to know, my turbos with a single pipe bolted off the turbo was LOUDER!
never heard my m3 with straights!
Old Feb 20, 2010 | 07:36 PM
  #70
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Has anyone tried putting "race mufflers" (straight through design) in place of the cats and have the whole pipe still be a foot and a half long when fabbing up straight pipes? Vibrant makes a 3 inch outlet/inlet diameter race muffler thats only nine inchs long. Cost only $78 each and if it removes some of the drone or the ear peicing scream it might be a cheap mod? Has anyone tried this?
Old Feb 20, 2010 | 07:44 PM
  #71
Almo's Avatar
I have thought about doing something similar but leaving high flows in original place off the turbos and instead of using a muffler or race muffler, use a small resonator with a small pipe still allowing the tips to work.
Old Feb 20, 2010 | 08:12 PM
  #72
gearhead's Avatar
Ya, I am just thinking of going catless and building my own set, it seems noboby has a used set they would like to get rid of. But I am slightly apprehensive only because of some guys with the usual noise/drone complaints and I figure that the race mufflers might help. I was hoping that someone had done this route and can chime in if its worth the time and money.
Old Feb 20, 2010 | 11:58 PM
  #73
Prche951's Avatar
I think Markski had that with his old setup, but not sure.
Old Feb 21, 2010 | 11:42 AM
  #74
WOODTSTER's Avatar
Yes,
I have been to a few F-1 races
Old Feb 21, 2010 | 03:34 PM
  #75
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Originally Posted by WOODTSTER
Hey Al,
Hi Marty,
Don't know. Placed a call to him recently and left a message. It was related to work I wanted him to do for me and I asked if he were still for hire. No response. I guess dead is a possibility.
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
