Diverter Valve Whistle?
Old Sep 23, 2009 | 01:37 PM
jleeev's Avatar
jleeev is infamous around these parts
Good afternoon all,
Recently installed a set of Standard Issue diverter valves as part of an K24/18G upgrade.
When first installed these DV's whistled and howled like crazy under boost however now 500 miles later they are barely audible.
Is this of concern or have they merely settled in. I don't think I'm experiencing any boost related issues but of course these big hybrids are already feeling a little "slow".
All thoughts most welcome.
Cheers,
J
Old Sep 26, 2009 | 08:11 PM
jleeev's Avatar
Bump......
Really, No one experienced in this phenomenon?
Best,
J
Old Sep 26, 2009 | 09:23 PM
John@SpeedTech's Avatar
My diverters have never whistled and howled under boost. They do make a slight "psst" sound on release of the gas pedal after a hard pull. I have had 3 styles OEM, Bosch Motorsports and Baily and none of them acted the way you described your first 500 miles with new diverters. It sounds like they are working better, now that they are broken in.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Sep 27, 2009 | 12:03 PM
jleeev's Avatar
Good morning John,
Thank you for your reply.....most helpful.
Cheers,
J
Old Sep 30, 2009 | 08:37 PM
jleeev's Avatar
Is nobody else running Standard Issue diverter valves?
J
Old Oct 1, 2009 | 08:50 AM
WOODTSTER's Avatar
The Bosch diverters should not/do not whistle.
The blow off valves on a NOBLE Whistle (you can hear them a mile away)
MY Bailey's let out a very audible pshhhhhhhhhhhhhht (almost like a bullwhip cracking), but that is due to the custom set up that I have and they are mounted
in the rear fenders on the intercoolers so you can hear them inside the car best.
Old Oct 1, 2009 | 09:14 AM
landjet's Avatar
Perhaps you have a hose leak. Mine are completely silent.
Old Oct 1, 2009 | 09:57 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
yea sounds like a leak. is the boost pressure normal?
Old Oct 1, 2009 | 10:10 AM
jleeev's Avatar
Yep.....boost holding steady @ 1.2. That's why I'm raising this question.
Boost had remained the same from when they were new and "howling" and now that they are relatively quiet?
Old Oct 1, 2009 | 10:17 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Mine use to make a slight whistle when it was coming into boost.
Old Oct 13, 2009 | 09:22 PM
BLKMGK's Avatar
So, since I am pretty sure I need a set of diverters (I'm not making near peak boost) should I go Bailey's or Standard Issue? My gut says Standard Issue and a Samco F-hose while I'm at it. However I do not wish to have to pull them to maintain them - will I have to with either of these? I don't mind whistling or wooshing much
Old Oct 13, 2009 | 09:42 PM
Yves's Avatar
Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !Yves Is a GOD !
I run a set of Forge DVs on a K16/24 Hybrid set-ups.
Between shifts, when getting off the gas, I get this noise whihc is somewhere between the 'pssssch' described above and a 'deep sigh'. Weird.
I run up to 1.3 bar pressure as of 3rd gear. Car pulls like a freight train.
Old Oct 14, 2009 | 07:46 AM
BLKMGK's Avatar
Question
I expect to be running that much boost as well but currently I'm not getting much over .8 and I'm pretty sure the DVs are the culprit. Question is which to go with and will I be needing to pull them out of that restricted space to maintain them? I supposedly have upgraded Bosch units onboard now but boost has fallen off for no apparent reason and is slow to boost so I believe the DVs or some other leak is at fault. The DVs will be my first step troubleshooting as I'd like to upgrade them anyway. Questions is - which ones? Sneezing, wheezing, and whistling don't both me much although if they blew to atmosphere and had whistles on them I'd object
Old Oct 14, 2009 | 01:25 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
i went with bailey dv's so i wont have to service them once a year
White991TT
Mar 8, 2016 06:01 AM
sdg1871
Nov 22, 2015 07:27 PM
flewis763
Oct 4, 2015 04:14 PM
