My Texas trip is hanging by a thread...
Old Oct 6, 2009 | 02:58 AM
  #76
yllwturbo's Avatar
yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !
Originally Posted by ttboost
I was leaning towards DV's too, but they are only 5000 miles old and the boost is holding fine? It's like a popcorn popping sound too, not honking...
my car is doing the same thing, but when i dialed it to spray less the sound went away, or when i turned it off. when we datalogged it it seems like the more we spray the leaner it got.
Old Oct 6, 2009 | 04:24 AM
  #77
ttboost's Avatar
Are you using meth? When you turn it off, are you still at the same boost level?
Old Oct 6, 2009 | 06:24 AM
  #78
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Glad you sorted out some of the issues, Keep us posted once you put it back on the road with some miles on it and see if it is gone for good!
Old Oct 6, 2009 | 10:37 AM
  #79
ttboost's Avatar
Thanks Corey, I'll keep everyone posted...
Old Oct 25, 2009 | 12:30 PM
  #80
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
how did this work out what happened?
Old Oct 25, 2009 | 04:00 PM
  #81
ttboost's Avatar
Never found it. Spet hours on the dyno, street datalogging, still there. Developed a check engine light at the Texas Mile, P0507 fault code (idle control at stop)? It seems my idle is a little high now too, so I am thinking a hose popped off somewhere and I have a vacuum leak. Still seems to run OK, went out and ran a few 6.1's today...
Old Oct 25, 2009 | 04:29 PM
  #82
vrybad's Avatar
vrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant future
Still not in the 5's yet?!
Jeeez, get with the program already!!
Old Oct 25, 2009 | 04:32 PM
  #83
ttboost's Avatar
Nope not yet. Get the lift ready, gonna have to drop the motor a little I think.
Old Oct 25, 2009 | 04:52 PM
  #84
Prche951's Avatar
I had the same code since I got all the new stuff put on and having been battling that code plus O2. I replaced my O2's, problem stayed. I went under tightened all the hoses and still existed. Checked it again and the compressor intake hose clamps were loose. I had tightened them but the clamps were as tight as they could go. They were to big. So I thought I had them fully tightened and they loosened up. Anyway, I thought I would share that. you definitely have a small intake leak probably. Not enough to slow you down much, but enough to cause codes now..I hate leaks
Old Oct 25, 2009 | 05:08 PM
  #85
ttboost's Avatar
Thanks for the input Dennis. I will likely have to put in on a lift and drop the motor a smidge and see if I can find something loose. It doesn't seem to lose boost and I did a boost leak test right before the Mile and all was well.
I just noticed today when I went out with the Pbox that it seems to idle around 1200-1500 now and won't ever come down. It seems to run fine but the stupid noise is still there.
Old Oct 25, 2009 | 05:11 PM
  #86
Prche951's Avatar
Mike, mine was doing the same idle crap. I would turn on the AC and it would drop a little. It is most likely on the vacuum side of the system. Did you get another code for O2 on one side or the other.
Old Oct 25, 2009 | 05:18 PM
  #87
ttboost's Avatar
Nope, no other codes. My car has run perfect until this. It only makes this popcorn sound between 4k-5k and it's not detonation or anything else we can datalog. It seem to pull right through the RPMs so it seemingly has no bearing on performance. The idle thing just started after the Mile. I got a check engine light the first day of the Mile and it wont reset. Today is the first day I actually drove it since the Mie and I just noticed the idle thing.
Old Oct 25, 2009 | 05:22 PM
  #88
Prche951's Avatar
definitely check out asap. Don't want something breaking off and stuffing your compressor wheel
Old Oct 25, 2009 | 05:24 PM
  #89
ttboost's Avatar
Right!!! Likel I need an excuse to buy the Alpha 30's
Old Oct 25, 2009 | 05:50 PM
  #90
Prche951's Avatar
do you need a reason to build a new engine?
