flashed X50?
Old Oct 15, 2009 | 03:21 PM
naptownmike's Avatar
naptownmike is infamous around these parts
flashed X50?
Has anyone flashed there X50 without burning up there clutch or is a new clutch part of the deal? thanks for any thoughts
mike
Old Oct 15, 2009 | 03:58 PM
SamboTT@ByDesign's Avatar
The clutch should hold o.k. up to 550tq.-ish. You may have a tired clutch already. You will want an exhaust and new plugs to get the most out of a flash though. Then there is an entire list of stuff you can do after that.
Old Oct 15, 2009 | 06:43 PM
titannero's Avatar
titannero is just really nicetitannero is just really nicetitannero is just really nicetitannero is just really nicetitannero is just really nice
If you have worn out the clutch a bit before the flash, the flash may have put it over the edge. Easy for that to happen, that is for sure.
Old Oct 15, 2009 | 07:19 PM
thanks for the responses I thought I had read most peoples clutch goes not long after they flash there car and some that had no proplems. I dont drag race or abuse my car but I geuss I wont know until I go for it.
thanks mike
P.S. I already have put on a EP 2 loud
Old Oct 15, 2009 | 07:33 PM
heavychevy's Avatar
Clutch will go eventually, and soon if you drive it hard.
Old Oct 15, 2009 | 10:04 PM
ard's Avatar
ard
If you flash AND exhaust, then yes it will eventually need replacing.
Old Oct 16, 2009 | 12:07 PM
thanks guys thats I guess I should have known the answer to that. Wishfull thinking on my part.
mike
Old Oct 16, 2009 | 12:44 PM
ard's Avatar
ard
mike
I'm not sure you got the answer I was reading... I have K24s, aggressive flash, exhaust, wastegates that hold 1.2...and a stock clutch. I will definitely need a new clutch eventually, but I don't think it is a "must do when you flash".
See what happens, don't drive it into the ground if it starts slipping (to protect the FW) and if it needs it then do it...
my 2 cents
A
Oct 6, 2015 06:13 PM
Oct 2, 2015 02:23 PM
