some early mile results
Old Oct 18, 2009 | 01:08 PM
  #166
Dr_jitsu's Avatar
Originally Posted by bmoores
I wish I did but I didn't. Infact Todd never touched the car all weekend. I'm still on the "base" tune. I spoke with Todd and Cynthia for a bit and we've got to just do more data logs now and see if there is anything left in the tune. As it turns out there are a few slight hardware differences between Anthony's car (Bobby's former car) and mine. Bobby's car does have a 9 second time slip and traps about 5 mph faster than my 138 trap. That is on C16 and significantly higher boost though. I was running MS109 @ 1.44bar.
Ben, are you not set up for C16.....do you still have cats and O2 sensors?
You are leaving some performance on the table if so.
Old Oct 18, 2009 | 01:19 PM
  #167
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Just got an text from Kevin: leftlanelife.com/showpost.php?p=49644&postcount=46
Last edited by GT3 Chuck; Oct 18, 2009 at 01:56 PM. Reason: embedded link to antother forum
Old Oct 18, 2009 | 01:53 PM
  #168
S-351's Avatar
S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !S-351 Is a GOD !
Has Rob beat anyone yet?...From what I understand he has never lost a race. (until this weekend) I would under promise and over deliver! I guess Rob does things a bit different.
Old Oct 18, 2009 | 02:02 PM
  #169
Divexxtreme's Avatar
Yes he does. He and the con-artist are identical in this regard.
Old Oct 18, 2009 | 02:03 PM
  #170
Originally Posted by KPG
Ben, the cars felt great. Tom and I saw 205 and 204 respectively on the box. Little headwind, not much of an issue. I will do a huge data dump on all the EVO cars later in the week. It was great meeting everyone and matbe we will see you guys again in the Spring. Take care and congrats on a phenomenal car!! Kevin
Great job, Kevin! I'm truly happy for you, brother!
Old Oct 18, 2009 | 02:07 PM
  #171
S-351's Avatar
Both clowns in my opinion Scott. Joe G has proven himself and these two clowns prove they can run.....Their mouths! Rob, you better get your **** togather before we race or else you are going to get assraped.....Again! I can't believe you think you are at the same level as Joe!
Old Oct 18, 2009 | 02:14 PM
  #172
jhuang25's Avatar
jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !
just got a call from turbo mike, art just ran 218. he's been having clutch issues as well as brake concerns... so hasn't run it at full boost yet, but they are setting up right now for another run.
Old Oct 18, 2009 | 02:19 PM
  #173
Prche951's Avatar
c'mon art!!!!! lets see that bad boy hit a high number....safely!!!
Old Oct 18, 2009 | 02:41 PM
  #174
MotorsportsR's Avatar
MotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to beholdMotorsportsR is a splendid one to behold
Did Turbo Mike run his car?
Old Oct 18, 2009 | 02:46 PM
  #175
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
just got a call from turbo mike, art just ran 218. He's been having clutch issues as well as brake concerns... So hasn't run it at full boost yet, but they are setting up right now for another run.
GO ART....uuuuu cn doooooo eeet'!
Old Oct 18, 2009 | 02:50 PM
  #176
jhuang25's Avatar
No, Mike didn't run his car... Art is turning the boost up and running it again soon! U CAN DO EEEET!!!!
Old Oct 18, 2009 | 02:54 PM
  #177
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
whats the top 996TT run of the meet so far? 224?
Old Oct 18, 2009 | 03:09 PM
  #178
jhuang25's Avatar
ok, another update. Art just did 221... apparently, his clutch is slipping really bad but they're going for another run and turning the boost up some more. He did the 221 at 30 psi into a headwind.
Old Oct 18, 2009 | 03:14 PM
  #179
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Art is doing really really well to be doing those speeds with the condition of his clutch. I can tell you without question he will be extremely happy with those numbers. His clutch was in pretty bad shape after yesterday. Well done buddy.
Old Oct 18, 2009 | 03:16 PM
  #180
cjv's Avatar
cjv
Moderator
Clutch is slipping real bad so they are going to turn the boost up.
