Poured 5 oz Castrol 5-30 GTX organic oil in my 996tt today - change the oil?
Old Oct 25, 2009 | 10:30 PM
bond's Avatar
bond is infamous around these parts
My mind was just elsewhere today and I poured 5 oz Castrol 5-30 GTX organic oil (for my G35) in my 996tt today before I came to my senses - should I change the oil?, I figure about 5oz Organic + 224oz (7 qts Syn) are in it now (about 2.5%). The syn oil has 1100 miles on it, it was idling at the time (naturally, otherwise I could just drain the tank...), so I just parked it in the Garage.
Old Oct 25, 2009 | 10:39 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
it shouldn't hurt anything if it was truely only 5oz it will get mixed in people run thicker oils in some cars with no issues
Old Oct 25, 2009 | 11:10 PM
bond's Avatar
I am mainly concerned about the high temperature coking inside the turbos and the impurities in the organic oil - the syn is very clean and tolerates very high temps compared to organic.
Old Oct 25, 2009 | 11:18 PM
in the 70's and 80's what kinda oil was in turbo cars? not synthetic
Old Oct 25, 2009 | 11:36 PM
bond's Avatar
Ummm - I guess my point was that I don't want the inside of my engine to look like a 70's and 80's turbo engine.
What I was really hoping to accomplish with this post was to hear from a member that is familiar with whether Mobil One in fact has some organic components in it or whether blow-by and other contaminants are in fact worse than 2.5% organic oil content, therefore a waste of time changing.
Porsche specified syn for a reason in this car.
Old Oct 25, 2009 | 11:42 PM
cause synthetic is a better oil holds heat better lubricates better you could still run organic in this car and it would survive perform worse? probably but i think your fine with a tiny bit of that oil mixed in, and if your so worried you could drain it but its probably not gonna change anything,
Old Oct 25, 2009 | 11:47 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
Sounds to me like you convinced yourself...
Old Oct 26, 2009 | 07:43 AM
madduc's Avatar
madduc is a jewel in the roughmadduc is a jewel in the roughmadduc is a jewel in the rough
I think the car is ruined. You will learn by this tragic mistake after you give me your car. Due to this your are sentenced to only drive a Ford Escort.
Seriously...even if you dumped in a quart they will be no loss of protection or damage to your engine. I wouldn't even give this a second thought.
Old Oct 26, 2009 | 08:02 AM
Porsche Tech's Avatar
Porsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nicePorsche Tech is just really nice
When Porsche converted to Mobil 1 from conventional i spoke with a Mobil1 engineer about this issue specifically. The jist of the conversation was that the two oils will mix just fine and the result of mixing conventional oil with full mobile 1 synth is that the lubricity and overall protective properties of the Mobil1 will be reduced by the conventional in a ratio proportional to the amount mixed. That said, the amount that you added is so nominal as to be insignificant. Don't worry about it. It will be fine. Even if you added a whole litre, i would still be relatively unconcerned although at that point you might want to have the oil serviced a couple thousand miles ahead of schedual.
Old Oct 26, 2009 | 08:56 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Just change the oil and don't do it AGAIN..............................
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
The Oss
Aug 24, 2015 08:19 PM
