Abs & psm
Old Oct 26, 2009 | 08:03 AM
REELDEEP's Avatar
REELDEEP is infamous around these parts
Question Abs & psm
Has anyone had a problem of their ABS & PSM system disabling itself? When I turn the wheel while leaving a parking spot, I get two codes that flash (ABS & PSM disabled) on my dash.
I have taken the front wheels off removed and cleaned the sensors. This did not work.
The computer (trouble shoot) indicates trouble with both front sensors.
It just started to happen out of the blue.
Pete
Old Oct 26, 2009 | 08:18 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Oh boy!!! get ready for headaches!
I just had to replace my ABS/PSM unit i did everything to locate the problem but it was the unit
Here is the thread
https://www.6speedonline.com/forums/996-turbo-gt2/186073-psm-module.html
Old Oct 26, 2009 | 09:47 AM
REELDEEP's Avatar
Thanks...but your thread has a bad link... wont open.... The shop said that the unit could have gone bad....what is the best price you have found?
Pete
Old Oct 26, 2009 | 10:00 AM
iJeremy's Avatar
iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !
Does it only do it on full lock of the steering wheel?... Have you had an alignment lately or a run-in with a curb? You could have a bad steering wheel sensor. I've seen it a number of times after a car has been aligned and the steering wheel isn't put back on at dead center.
Old Oct 26, 2009 | 10:07 AM
Old Oct 26, 2009 | 10:13 AM
r_matt_6's Avatar
r_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud of
Seems to be a very common problem with these..
From what I've read here it could be caused by a NUMBER of things. This just happened to me recently. My codes read that I had a faulty steering angle sensor and speed sensor. About $1k later and 10 days at the shop waiting for parts, it did NOT fix the problem.
I was then advised by other members here to clean my MAF. I did that and it solved the problem. It was a 2 minute fix which cost me nothing.
Good thing it was a simple fix for me. There's another guy here who ended up replacing a chunk of his wiring harness to fix the prob.
Old Oct 26, 2009 | 12:52 PM
REELDEEP's Avatar
I read that it could be the MAF...I will clean It...Ill use some carb cleaner.
Yes Jeremy....it does happen when I turn the wheel fully L or R... I will get it alignied...it has been a while.
Thanks.
Old Oct 26, 2009 | 12:58 PM
wross996TT's Avatar
First please post the actual codes (#s) also MY, model and mods. There are many things which will cause the ABS, PCM dash lights to illuminate.
Old Oct 26, 2009 | 02:38 PM
ttboost's Avatar
Thanks.
Do NOT use carb clean. A MAF is not a carburetor, it is a delicate electronic device. Use a cleaner that leaves no residue like electronic parts cleaner...do a search here...
Old Oct 26, 2009 | 02:56 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
+1 for Statman. Anything from MAF to steering angle sensor to something actually in the PSM/ABS can cause this light. Get the codes read. This pair of lights could be replaced by one that says "WTF?"
Old Oct 27, 2009 | 04:46 AM
REELDEEP's Avatar
I need the lights that say "WTF"....everyone should have them. I wont use carb cleaner..I talked to my mech and he said the same thing, use a electronic parts cleaner "permatex".
Old Dec 31, 2009 | 07:15 AM
REELDEEP's Avatar
Well...after 4 months of trouble shooting I fixed mine. I first started with the trouble codes. It indicated right front sensor not reading. I cleaned and switched speed sensors form L-R on the front. Did not help. (there is a way to test the wheel signal....with the sensor off, put an om meter where the sensor goes and spin the rotor, you should get a pulse).
I read a post on this web site that said WIRES BREAK INSIDE THE HARNESS. Sure enough....after carfully splicing the harness open...alll the way up into the firewall...i found broken wires. PROBLEM SOLVED!!!!!
Bmw M3 Guy
Feb 21, 2018 09:29 AM
randalldahme
Feb 19, 2016 03:56 PM
ophtho
Sep 18, 2015 03:00 PM
JWrightPNH
Sep 17, 2015 01:42 PM
dgreen78
Cayenne 955/957
Sep 12, 2015 11:44 AM
