Boost BAR
Old Dec 5, 2009 | 09:28 PM
996-X50's Avatar
996-X50 is infamous around these parts
Boost BAR
HI, Can someone tell me what is the normal boost bar in an X50 pakage with unchange ICU? and how do i check for boost leak? do i need a specific device? I think my maximum boost bar is 07, is this normal?
Your input is highly appreciated...AL
Old Dec 5, 2009 | 09:54 PM
thats normal...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 5, 2009 | 11:07 PM
BLKMGK's Avatar
Do a search for the DIY pressure tester to check for leaks. Even with a leak you might still see normal pressure - the turbos will just be spinning harder to compensate for loss of air volume is all. Would be slower to boost and the IATs would be hotter as well most likely. It's fairly easy to test if you have a compressor and the tool to do it isn't hard to make - been there done that...
Old Dec 5, 2009 | 11:53 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Before headers and an exhaust I could hit .8 bar but not hold it. Since the change I've been able to hit and hold 1 bar (2nd and 3rd gear, I hit the rev limiter in 1st gear before I can get to 1 bar). I'm also X50. Change out the exhaust, it makes a world of difference.
Old Dec 6, 2009 | 12:17 PM
996-X50's Avatar
I got in the freeway this morning at 5:30 at 3rd gear; i got only to 04 in WOT but when i shefted to 4th gear in WOt, the Boost bar reached to 09 for a moment. i tried that few more times with 09 at boost bar, therefore, i think everything should be dandy. Thanks everyone for your input.
Old Dec 6, 2009 | 02:03 PM
BLKMGK's Avatar
Is it showing this right as you shift? I've noticed on shifts that sometimes the DVs don't completely catch the spike and the gauge will show an elevated number for a second. From the description it sounds like you hold .4 in 3rd and don't go higher till 4th. That could be a boost leak and it would be worth testing for if you have a compressor - the tool to do it from the MAF is NOT hard to make. A fitting, a clamp, and some JB Weld with a bit of driling...
Old Dec 6, 2009 | 02:34 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
put third gear at 2000rpm and hit it...(on a flat surface)it should hit 0,8 and be steady there...not just a spike...
Old Dec 6, 2009 | 06:19 PM
996-X50's Avatar
I think one of the reason i only got to .4 boost at 3rd gear was because I already reached the red zone in my RPM and i must shift to the 4th gear. does this make sense? I will try the 3rd gear at 2000 RPM and will hit it hard to see what the reading would be.
Rguy
Apr 12, 2020 11:11 PM
Fadi
Aug 17, 2018 05:16 PM
Fadi
Oct 5, 2015 12:14 AM
maroli
Sep 15, 2015 07:07 PM
jpik2003
Sep 10, 2015 05:18 PM
