agency Power Diverter Valves
Old Dec 13, 2009 | 02:09 AM
mitcho168's Avatar
mitcho168 is infamous around these parts
Thumbs up agency Power Diverter Valves
hi i am planning to get agency Power Diverter Valves with the f hose. i have no mods just an exhaust. planning on intake. but i want to hear the turbos spool im running stock boost. will it have any negative affect if i put agency Power Diverter Valves. would it decrese my reliability ? anything bad can happpen thanks please help me. it seems to be at a fair price and i want to hear some noise from the turbos thanks!
Old Dec 13, 2009 | 02:33 AM
996twin_sc's Avatar
996twin_sc is infamous around these parts
The plastic DV's tend to break. Upgrading them is always a good thing.
Old Dec 13, 2009 | 02:51 AM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
upgrading your diverter valves won't hurt anything, the stock diverters are plastic and fail fairly easily. But they will make no "turbo spool" noise, if you did hear anything at all then somethings leaking boost and hurting your performance. The easiest way to hear turbo spool aka mac truck sound is to run a straight pipe exhaust but be warned its retarted style loud. But if you want to hear a whoosh or pphhh sound everytime you shift and perhaps thats what you were meaning as turbo spool, agency power makes a single style blow off valve that replaces your two diverter valves. Some purest might complain thats its not a rice burner and running atmospheric instead of recycling your boost will cause the car to run rich but I have one, love the noise and have no issues of running rich. Just go 50% recycled 50% atmospheric and you will have no problems. Install is easy enough just a pain because there is no space on top of the engine. Hope this helps your decision.
Old Dec 13, 2009 | 05:45 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
They offer no performance benifit unless the old ones have failed. That said, I switched mine out and they look good!
Old Dec 13, 2009 | 09:30 AM
BLKMGK's Avatar
The DVs won't make it any louder. Try to choose DVs that aren't big and bulky too since space is QUITE limited and if you go way bigger than the OEM plastic you will be hating life installing them - ask me how I know!
Old Dec 13, 2009 | 11:39 AM
mitcho168's Avatar
ok thanks for your response guys i really appreciate it. so if i change it it will not change any noise or anything?
Old Dec 13, 2009 | 01:10 PM
BLKMGK's Avatar
I observed no difference in sound upgrading mine and I doubt you will either. They do not vent to atmo, they'll be muffled by venting into the intake. I'd only swap them if you had good reason to believe that the OEM ones had gone bad or you were turning the boost way up...
Old Dec 13, 2009 | 01:19 PM
mitcho168's Avatar
alright sounds good thanks alot i appreciate it.
Old Jan 8, 2010 | 04:17 PM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
my evoms gave a small swoosh sound with the k&N drop in
Old Jan 9, 2010 | 11:09 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
using the AP, no noise difference. i dont think diverters (as opposed to blow off valves) make noise.
if diy this, drop the engine, saves a lot of time, avoids breaking things in the process, and easier to make sure hoses are tight enough. really easy to do, 2 bolts underside. there's a good link on this forum on how to safely do it.
To save a lot of hassle. get new hose clamps to replace the OEM spring type for the 2 OEM hoses that the diverters connect to on the other side of the F hose. Same applies if using the OEM F hose. AP F hose comes with hose clamps.
the vacuum hose that goes bottom side from diverter Y connector to a hard line may be brittle. i replaced mine.
Old Jan 9, 2010 | 11:46 AM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
dv do go woooosh at least me forge ones did until i add evos piping to the turbos,that gave me way more power but lost my wooooosh i miss it
drinaldis
Sep 28, 2015 01:37 PM
Superaudiofreak
Sep 4, 2015 03:22 PM
Ferrari
Aug 24, 2015 04:35 PM
VGLNTE1
Aug 20, 2015 08:14 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
