EBC problem
Old Jan 7, 2010 | 12:41 AM
P2P's Avatar
P2P
P2P is a jewel in the roughP2P is a jewel in the roughP2P is a jewel in the roughP2P is a jewel in the rough
Question EBC problem
Hello There ,,
I've a 996 tt with upgraded turbos (k2418g). protomotive flashed ecu. dvs. evoms v-flow intake. gt2 intercooler. greddy profec b spec 2 boost controller.
from the first time i have put the EBC i'm getting wrong pressure reading in the EBC screen. like when i start the car it appears 99 PSI then it is decreasing when ever i push the gas pedal in both on and off modes. i get my car back again to the work shop to see if some thing attached wrong but they sayed that every thing is in its position and attached very good. This EBC i had it from my friend he was using it for another car before.
So any one got this problem before wanted to share now the solution ?
Old Jan 7, 2010 | 01:18 AM
laurent965's Avatar
laurent965 is infamous around these parts
I put red EBC on my car , after 8 laps on the track , they were fried , complety gone.
But on the road the were fine
Old Jan 7, 2010 | 04:41 AM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Lost in translation?
Old Jan 7, 2010 | 04:59 AM
ttboost's Avatar
He thought you were talking about electric brake pads...
Old Jan 7, 2010 | 05:38 AM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
EBC = brake pad company.
EBC also = Electronic Boost Controller
Old Jan 7, 2010 | 06:34 AM
Mr. C4's Avatar
Rather obvious P2P was talking about an Electronic Boost Controller.......................
Old Jan 7, 2010 | 06:45 AM
ttboost's Avatar
obviously not obvious to our french friend...
Old Jan 7, 2010 | 07:50 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
woof
Old Jan 7, 2010 | 08:02 AM
justinn's Avatar
justinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to behold
woof woof?
Old Jan 7, 2010 | 08:04 AM
justinn's Avatar
Originally Posted by P2P
Hello There ,,
Are you sure you are reading pressure? Can you draw a diagram of how it is installed? Have you set it up correctly?
Justin
Old Jan 7, 2010 | 10:10 AM
turn off the greddy with the top little button so it reads OFF.. have someone look at it while your driving... get on it in 3rd and see if it reads .8 bar or so... or maybe 12 psi depending on your setting...
here is how you should have it hooked up:
Connect the NO port to the port off of the Y-Pipe just outside of
the throttle body.
The COM port should go to the line that runs up over the manifold
and T's off to the w/g actuators.
The NC port should go to the line that runs towards the drivers side
of the car, then to the rubber pipe that holds the diverter valves.
Be sure that all the little red plugs are out of the solenoid!
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 8, 2010 | 01:05 AM
laurent965's Avatar
Sh....t next time i should read the post before writing something. hoops
Old Jan 10, 2010 | 11:29 PM
P2P's Avatar
P2P
I'm sure that every thing is attached properly but still reading 99 PSI when i start the car and when i'm under the full boost it reads 1 or 0 psi some times.
Old Jan 11, 2010 | 04:21 AM
ttboost's Avatar
Not to state the obvious, but it appears that you are not getting a boost signal. Are you sure you are hooked to a hose that gets positive pressure and not JUST vacuum?
Old Jan 11, 2010 | 04:45 AM
P2P's Avatar
P2P
Am gonna do a double check today in the work shop. But last time we have changed the lines and still the same.
