TESTED - Boost Logic Intercoolers and stock Turbo ICs
Old Jan 12, 2010 | 07:01 AM
  #31
justinn's Avatar
justinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to beholdjustinn is a splendid one to behold
Originally Posted by BLKMGK
Like the looks but you REALLY need a Y-pipe!
hahaha.... you got jokes
This setup is designed to work with the MAF in place as well as the stock filter box in place. It looks weird cause I have the piping for it, and neither is present
Justin
Old Jan 12, 2010 | 07:09 AM
  #32
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Originally Posted by Boost Logic
Are there any modifications to the mounting brackets required for the BL 4.5's ??
Old Jan 12, 2010 | 09:29 AM
  #33
justinn's Avatar
no modifications to the bracketry necessary. Only a slight modification to the intake plastic as you can see in the pictures. We preferred to keep the plastics all intact as opposed to deleting them.
Justin
Old Jan 12, 2010 | 09:51 PM
  #34
BLKMGK's Avatar
Ah, it is now much clearer to me why the upper duct must be deleted to run intakes up there. Seems like there must be a good way to seal an intake with filter in there so it doesn't catch too much dirt with that top duct removed.... Like the looks of the ICs!
Old Jan 12, 2010 | 09:59 PM
  #35
justinn's Avatar
you cannot see it in the pictures, but my filters are next to the upper ducting. My wheel well plastics are not installed in the picture, but I assure you I run with them 100% of the time. The filters will get dirty, it's just the nature of putting them behind the tires It's livable though. I cleaned mine once in 8000 miles and it wasn't absolutely necessary to do it then. I just happened to have them out, so I did it.
justin
Perkman87
Nov 19, 2015 05:31 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
Vrseis
Aug 20, 2015 07:41 AM
oddjob142
Aug 19, 2015 12:27 PM
