Quality Lug Nuts Needed......
Old Jan 16, 2010 | 01:45 PM
Ricie168's Avatar
Ricie168 is infamous around these parts
Converted my 996 TT wheels bolts to studs.....tired of trying to line up the wheel before putting in the wheels bolts. Bought the studs from H&R, but need quality lug nuts (14x1.5)....dont want the cheap alumium lug nuts on Ebay or the acorn style nuts......any suggestions?
Old Jan 16, 2010 | 09:17 PM
Arnie1's Avatar
Arnie1 has a spectacular aura aboutArnie1 has a spectacular aura about
use the tool in the tool bag to line up the wheel it is easy . Just screw it and put the wheel on it to hold it in place.
Old Jan 16, 2010 | 09:51 PM
Turbo Fanatic's Avatar
sounds like a lot of work. I like the lug bolts, easy to replace and have different lenghts in my garage depending on spacer i'm using.
Old Jan 17, 2010 | 04:47 AM
Ricie168's Avatar
By using the aliment tool.......still requires holding up the wheel onto the mouting face of the brake rotor and the wheel is just hanging on the center hub lip......had the wheel come off that lip a few times and scratch up my inner wheel.......
Old Jan 17, 2010 | 05:42 AM
Arnie1's Avatar
When I use the alignment tool the wheel hangs on the alignment tool not on the center hub. I than just take a bolt swing the wheel on the alignment tool till I get the bolt in and lightly tighten it. I do it for 4 bolts and than remove the alignment tool. My Audi uses the same procedure never an issue of the wheel falling off the alignment tool while hanging on it.
Old Jan 17, 2010 | 06:30 AM
No SubstiTTute's Avatar
No SubstiTTute is infamous around these parts
I have used two alignment tools to mount the wheels. It makes it go much faster, especially with bigger wheel/tire setups.
Old Jan 17, 2010 | 11:17 AM
Ricie168's Avatar
Thanks for all the suggestions......but already got the wheel studs and trying to find the lug nuts......
Also.....lot faster tire change at the track.......
Again....thanks for the suggestions......
I think I will just have to make them myself.......lucky that I have my own factory overseas......just need to buy some Titanium (6A4V) material and machine it out.....
Old Jan 17, 2010 | 01:20 PM
grandpa's Avatar
grandpa is infamous around these parts
Old Jan 17, 2010 | 01:42 PM
Ricie168's Avatar
grandpa......THANK YOU VERY MUCH FOR YOUR LINKS.....but they are mostly acron style or close end lug nuts....
Want something long and open end........BUT THANK YOU VERY MUCH!!!!!!
Old Jan 18, 2010 | 08:52 AM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
RAD USA Direct was very helpful to me and have both spacers and cold forged Greman Steel lug bolts in any size you will need.
Old Jan 18, 2010 | 10:44 AM
Ricie168's Avatar
Thanks......but I am looking for something like this......the R40......
http://www.mackinindustries.com/wm/k...utcomposi.html
Old May 12, 2010 | 09:58 AM
Ricie168's Avatar
Finally.....got my Titanium wheel nuts done......will be installing it when I get back home.....
Old May 12, 2010 | 10:46 AM
Man that is cool, Titanium... Sweet!
Old May 12, 2010 | 11:11 AM
Ricie168's Avatar
Thanks......hope it will look good on the wheel.....we will see this weekend when I get back home from my trip.......
Old May 12, 2010 | 01:54 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
