K16 Sticking waste gates - how do you check?
Old Feb 8, 2010 | 11:36 AM
Janker's Avatar
Janker is just really niceJanker is just really niceJanker is just really niceJanker is just really nice
What's the easiest way to test these in situ? - Can you hand operate them from under the car?
Thanks,
James
Old Feb 8, 2010 | 11:41 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Thanks,
James
On the right side of the throttle body locate the boost control valve.
Disconnect the 1 line (there are 3 lines total) that splits off down to each wastegate. Using compressed air or a hand pump, apply pressure to the line (may be better to have a helper do this) and watch the wastegate rods for movement.
Old Feb 8, 2010 | 11:42 AM
Janker's Avatar
And how do you free them off (assuming you can?)
Old Feb 8, 2010 | 11:43 AM
Tony@epl's Avatar
Free the vacuum line off? Just pull.
Old Feb 8, 2010 | 11:44 AM
Janker's Avatar
Thanks - can you operate them by hand (by moving the rod) to work out of they are jammed? - No idea where the throttle body is sorry!
Old Feb 8, 2010 | 11:45 AM
Tony@epl's Avatar
Just moving the rod by hand isnt going to give you the whole story. You may want to have a good shop to help you out with this one.
Old Feb 8, 2010 | 02:24 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Hey Jim
Have you found anything yet?
Old Feb 8, 2010 | 03:12 PM
Janker's Avatar
Not yet - planning to have an initial look tomorrow PM/eve all being well/depending on work. You about?
BTW - if you need a SSK fitting I can help you with that - did mine a little while ago and makes a massive improvement over stock shifter.
Old Feb 8, 2010 | 03:24 PM
ant_8u's Avatar
I'll definately take you up on the SSK when I get one
Did you do the 997 swap?
I'll be available if you need any help tomorrow
I'm not sure your problem is sticking wastegates
True, that would cause you to overboost, but it wouldn't cause juddering and hesitation
This doesn't mean you don't have a problem elsewhere with the WGs though, you could have a problem with the vacuum lines
I'll put a list on your other thread of things you might want to check
Old Feb 8, 2010 | 05:07 PM
Janker's Avatar
Think your right - from what I've read tonight (attached for reference) all appears to point at the area of vacuum hose/s.
Right – post number 7 & 9 seems promising..
https://www.6speedonline.com/forums/996-turbo-gt2/168401-gt2-boost-pressure.html
Or number 24
https://www.6speedonline.com/forums/996-turbo-gt2/162846-how-tell-what-modifications-done-already-2.htm
Did you manage to locate your pressure testing kit?
PM me your number and I'll give you a shout tomorrow afternoon if I can make it. I may swing past Shirleys and get the codes read first which is over your way isn't it?
Cheers,
Jim
Old Feb 9, 2010 | 03:39 AM
ant_8u's Avatar
Yes, Shirleys is about 10 minutes from me
Just sent you a PM
Old Feb 9, 2010 | 02:12 PM
Janker's Avatar
Right - I have a very stiff/stuck wastegate - how do you free them off? - The actuator is fine..
DB-Design-Group
Group Buys
46
Nov 3, 2015 11:27 AM
jaehoppa
Oct 22, 2015 09:17 PM
davetherave
Bentley
Sep 16, 2015 06:30 AM
GSP
Sep 9, 2015 05:31 AM
