Even Bigger Brakes... Yum!
Old Feb 13, 2010 | 01:55 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Just thought I would share some pics...
Worked on Brakes all day today with my wrench man Matt (Big thanks again bro) and after a few minor mods here and there managed to get this 380mm set up with RSR bells to work... was running the Brembo 350's, be good to see the difference.
Old Feb 13, 2010 | 02:08 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
Beautiful Stevo - really fills out the open area of the wheels!
What parts did you use and did you weigh the setup to see if you lost weight with this setup?
Old Feb 13, 2010 | 02:21 PM
Mikelly's Avatar
Looks good Steve! Are those 18inch wheels you're fitting them under?
Mike
Thanks... nothing in the weight as the bell is only slightly larger, using the Performance Friction race rotor, it has been custom done though and we had to shave about 1mm from the bottom of the inner caliper... really happy with the results.
Old Feb 13, 2010 | 02:23 PM
Yip, Mike 18" CCW
Old Feb 13, 2010 | 02:27 PM
Mikelly's Avatar
Stevo, Was it about 22-24MM in spacing to get them to align with the plane of the rotor edge??
Very impressive!!
Mike
Old Feb 13, 2010 | 02:33 PM
RiA's Avatar
RiA
Are those standard 6-pot GT3/GT2 calipers with just 1mm shaved? Did you use spacers to shift the calipers farther out?
Nice job...
Old Feb 13, 2010 | 02:36 PM
Mikelly's Avatar
They're definitely 6 piston GT2/3 calipers...
When I did this with 350MM rotors, I didn't have to use a spacer, but I'd suspect Stephen had to use large spacers in spacing out the caliper to meet the rotor...
Mike
Old Feb 13, 2010 | 02:37 PM
yes... 15mm shim with stock 6pot
Old Feb 13, 2010 | 02:47 PM
RiA's Avatar
RiA
Beautiful - thanks guys.
Old Feb 13, 2010 | 03:10 PM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Wow, 380mm in 18".
Stevo, have any pic of how you do it? Where to get that shim?
Old Feb 13, 2010 | 03:30 PM
Shim custom made by Brembo, 100mm bolts... everything is spot on, taken the whole day just to make sure everything was working correctly.
Old Feb 13, 2010 | 03:35 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Crikey Steve! They look nice
What rears are you using?
BTW, those wheels and tyres look very nice too
Old Feb 13, 2010 | 03:41 PM
Hi Ant... using 350mm Alcons on rear
Old Feb 13, 2010 | 03:46 PM
Neil A's Avatar
Neil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud of
Looking good Stevo , did you get the rears done aswell ? When is the first outing for the car after the winter upgrades.
Thanks alot again for the shot of the lead .
