996 turbo Factory Offset Info
Old Feb 18, 2010 | 09:52 PM
PorschePair's Avatar
PorschePair is infamous around these parts
We're looking to replace the factory turbo twists on our 04 996T - having a hard time tracking down what the standard specs on the wheels/offsets are so we can determine which wheels will work with our car and what spacers we'd need for them. Anyone know this info or point us to a site that would help?
Last edited by PorschePair; Feb 18, 2010 at 10:11 PM. Reason: More coherent wording....tired!
Old Feb 18, 2010 | 10:37 PM
GT3 Chuck's Avatar
Administrator
I believe they are:
8x18 50mm, 11x18 45mm.
you can verify with the info stamped on the wheels themselves..unless you have owned the car since new you can't be sure they are the original wheels and I would verify with the stamps on the wheels
Old Feb 19, 2010 | 07:58 AM
landjet's Avatar
Chuck gave you the correct offsets for the stock wheels. Many go with smaller offsets on after market wheels in order to push the wheels out so they fill the wheel well better. Best to check with the wheel professionals about this.
Old Apr 30, 2011 | 02:52 AM
Turbo Fanatic's Avatar
Factory spec is 8" x 50 and 11" x 45 for the TT and 8.5" x 40 and 12" x 45 for the GT2
Both proven sizes with no rub (if you roll the rears like the factory does with the GT2)
You can go with 8" ET 50-35, 8.5" x 40 (with 225-245 make sure they're the same height or very close to your rears on an AWD setup (height differs by brand). I have a set of 9.5" fronts coming hoping to go with 265s. Lets see how they fit
11" from 45-25 offset (with 295-315), 12" from 45 to 38 offset (with 315s)
Old Apr 30, 2011 | 08:11 AM
landjet's Avatar
Please post up your results ari, I will be interested in what you find. Do you track your car?
Old Apr 30, 2011 | 08:20 AM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Ari the 265/35/18 fr with a 315/30/18 r would be pretty much a perfect match if they fit. Keep us posted.
Old May 2, 2011 | 06:10 PM
Will keep you all updated. Waiting for rims to arrive.
Old May 3, 2011 | 09:33 PM
SamboTT@ByDesign's Avatar
They should fit...i've done it with HRE. If you need any little spacers like 3-5mm to get the fit right let me know.
Good luck!
Old May 16, 2011 | 11:03 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Would these fit a 996tt?
18x9 et54 fronts
18x12 et51 rears
Old May 18, 2011 | 12:38 AM
sunir's Avatar
anyone know if you can get a 335 out back on a gt2? w the factory 12" et 45 maybe with a slight spacer? the factory rolls the rear fenders perfectly probably with a machine on the assembly line...so outer rub should be ok w camber gain its the inside I am worried about....
Perkman87
Nov 19, 2015 05:31 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
