My K24 turbos are junk! advice!
Old Mar 15, 2010 | 09:47 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Originally Posted by Eric@AMS
You could run our Billet K16 upgrade. Peak power is very very close to a K24/18G however the billet K16's deliver a much quicker spool and gobs more torque down low. All in all its a much more solid power band.
here is a review thread: https://www.6speedonline.com/forums/...ar-review.html
Here is a link to the product on our site: http://www.amsperformance.com/cart/A...-Upgrades.html
Please PM if you have any questions at all
Eric
What ECU changes do you need to run these on a factory K24 car.
Old Mar 16, 2010 | 02:56 AM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
As to the pic above with the destroyed wheel - catalytic is AFTER the turbo so no there should be no chance of that. It's possible the wheel was overspun and exploded perhaps?
I was thinking the same thing.
Old Mar 16, 2010 | 07:00 AM
ThePunisher's Avatar
ThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud of
In this specific situation it was not an overspun but a foreign debris or shaft failure due to oil starvation.
Sorry for the off-topic
Ciao emadelta !
Old Mar 16, 2010 | 03:30 PM
emadelta86's Avatar
Ciao!
Oh, well, time for some K24/20g now!!! And then those GT3 will be left on your rearview mirror forever!!!!!
Old Mar 17, 2010 | 04:00 PM
formulab's Avatar
formulab is infamous around these parts
Originally Posted by Kevin
I would ask "How were they ruined"
Are the wastegate doors warped? Are the turbine housings cracked in the wastegate port? The wastegate bushings can fail and lock the internal gate.
The K24 has been out since the middle 90's. I have seen very few failures with this housing. Unless, one has been running lean>>high EGT's will crack the internal casting.
If the turbine housings are cracked>>toss them in the scrap pile.
Kevin,
talked to mike again at blouch. he said the wastegate flapper doors/discs were damaged. on one turbo it is very loose, on the other turbo it is missing. he said because the wastegate was always open, that the exhaust gases go in and ruined the flappers. hope that makes sense to you. when i receive them back, i will snap pictures for ya.
bob
Old Mar 17, 2010 | 04:15 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
There's a guy selling his K24/18g in the for sale section for $2400. I would look into that.
Old Mar 17, 2010 | 08:17 PM
unvmy996's Avatar
Originally Posted by formulab
Kevin,
bob
ok so if that was the case , you were overboosting ??
Old Mar 17, 2010 | 10:32 PM
BLKMGK's Avatar
No if the flappers were open he was bypassing the turbo. He may have been running with just one turbo boosting and the other spinning like mad trying to help - not good. When he slaps working turbos on there it will feel like a new car
Old Mar 17, 2010 | 11:19 PM
formulab's Avatar
last couple months have only seen .9 bar at most, and when decel to around 2k rpms can always hear a exhaust rattle. blouch believes that rattle was the loose flapper. loose flapper, thats sounds funny
anyway, i'm buying "dgreen78" k24/18gs and epl's programming. i'm excited to feel the car performing like it can.
Old Mar 18, 2010 | 04:19 AM
ReeknHavic's Avatar
I think you're going to feel like you're driving a totally different car once you get both of your 18g into boost.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
BlackMarketRacing
Dec 3, 2015 10:46 AM
pilotscottb
Sep 1, 2015 10:29 PM
SteveH
Aug 23, 2015 12:13 PM
