Single BOV Installation
Old Apr 22, 2010 | 02:42 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
I wanted to get opinions on this BOV setup. Im chasing down a boost or vaccum leak and replacing all hoses. Before I touch the F-pipe, I wanted see what you guys thought about replacing it with something similar to this setup from a post a couple years ago but with a straight reducing pipe to not look out of place.
Basically want to eliminate the F-pipe altogether and run a BOV venting 50% to atmosphere.
Originally Posted by jimmer23
Well, I finally got the matching silicone hoses so I could make a new BOV connection and get rid of all of the rubber junk underneath. Here's a pic of everything that was pulled out:
What I did was order:
1 38-25mm 90deg reducing elbow coupler (connect to Y-pipe and BOV)
1 38-25mm straight reducer coupler (connect to intake and plug)
1 89mm hump coupler (connect to MAF and intake)
Rerouted some vacuum lines, and repositioned the BOV to a more adjustable position. Really happy with the outcome, plus I got rid of some useless solenoids in the process. I just hope my engine bay isn't too dirty for Oak
Old Apr 22, 2010 | 03:11 PM
gt2rs6's Avatar
gt2rs6 has a spectacular aura aboutgt2rs6 has a spectacular aura about
that looks awesome ... how does it drive and sound?
Old Apr 22, 2010 | 03:13 PM
ColoradoSilver's Avatar
ColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud of
From what I've seen, most prefer to go with upgraded diverter valves and better F-hose at the same time. I'm not sure that there's anything to be gained by going to the single BOV setup., unless you're just looking for the BOV sound.
Maybe someone else can chime in here.
Old Apr 22, 2010 | 03:17 PM
NOLA911's Avatar
Personally, I have no idea what a BOV sounds like. I hear the youtube videos of the Jap cars that have BOV whistles, but dont know how this would sound with a normal BOV. I'm told it is great.
My goal is to build an easy to adjust system with little room for failure and I really like the look of the BOV setup as I dress up the engine bay
Old Apr 22, 2010 | 03:27 PM
Fair enough then.
I would think that the easiest way to do this would be to get a "Y" pipe to connect to the old diverter valve intake Or single pipe and plug the other hole. Then connect single vaccum line in place of the old double line.
I have no idea how this will effect the MAF or ECU codes.
Old Apr 22, 2010 | 03:41 PM
gt2rs6's Avatar
i would like to know if the agency adj BOV givs the car any driveability issues... and if you can adjust it to full recirc while its installed in the car..
Old Apr 22, 2010 | 03:43 PM
Thats definitely a question for Dan @ Vivid.
DAAAAAAAAAANNNNNNN! ....
Old Apr 22, 2010 | 03:48 PM
NOLA911's Avatar
It's actually Dan @ vivid who is helping me right now with my "mini-build"
Another question is- Can anyone tell if the guy who did this mod originally replaced the flange between the MAF and the Intake for a specific reason or just to have another blue hose?
Old Apr 23, 2010 | 12:19 AM
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
I use another brand of BOV. A 38mm single unit with option to adjust ratio of recycle-external blow. (I noticed bigger cross-section area than 2 OE combined.)
Work fine. And I had toxicated BOV sound that I missed back. (habit from 10y+ of driving mod japanese turbos.)
Old Apr 23, 2010 | 07:09 AM
NOLA911's Avatar
Can you link me to the BOV that you use?
Old Apr 23, 2010 | 08:19 AM
+1
#TeamAIM
Old Apr 23, 2010 | 09:32 AM
vividracing's Avatar
Jimmer did something funky with his. The BOV can be installed the same as stock, but you only use 1 unit. The BOV can be set to recirc 100% like a diverter valve or 50/50 to get that whooooosh sound without affecting MAF readings and having the car stall. Read here - http://www.vividracing.com/catalog/a...5-p-35830.html
http://www.youtube.com/watch?v=3jotz...layer_embedded
Marcos AMV8
Dec 18, 2015 06:03 AM
Perkman87
Nov 19, 2015 05:31 PM
Sales@RSW
Sep 3, 2015 09:34 AM
Money2536
Sep 1, 2015 04:56 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
