Help, Big Fuel Leak!
Old May 22, 2010 | 11:55 AM
legendr34's Avatar
legendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud of
Originally Posted by smdubovsky
Judging by the gunk on the bottom of the motor (and the oil drips clearly visible), he's had an oil leak for some time...
But if he says its gas I'll believe him that its probably gas. C'mon, it doesn't evaporate THAT quick. Plenty of time to get out and take pics. Plus it looks like its cleaning off/eating though the oil sludge like any solvent would do. Going to have to dig from the top side to find it no matter what.
FWIW, Also looks like the oil has been attacking the water line seal (though there are 2 o-rings down inside that may still be fine.)
I believe you are correct, I don't believe it has an oil leak, I park it in the garage and i never even seen a drop of oil on the floor, it appears that the gas was acting as a solvent and eating away at the old sludge like you said. I now just need to find the source of the leak....
thanks for the replies guys
Old May 22, 2010 | 12:00 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
check the filter area and lines around it to start with. Like the other guy said, do a key-on engine-off. May help to pull the airbox for a little more room to see around there.
Old May 22, 2010 | 12:43 PM
legendr34's Avatar
Originally Posted by Kevin
The inlet piping for your fuel filter is a snap lock fitting (with a oring) It is tucked up against the sound padding.
The other source would be the EDM rubber/teflon line from the fuel filter to your fuel rail connection. There is a pressure tap located on this line.
The other sources of fuel would be your fuel rails or the cross-over fuel line that connects both banks of rails.
Since this looks like a Bank 1 issue>> I would look at the fuel filter. As mentioned you can turn the key to the 1 o'clock position and you will energize the fuel pump.
Don't start the car for any reason. You can call me today 360.805-9066
Kevin, thanks for your info, but I started the car for before I read this and I think I found the leak.
There are two small punctures on this hose where fuel is leaking out. It looks like is leaking out a tremendous amount since I can actually see the fuel "flowing" out of punctures...
I believe it's called the fuel return line? Looks like I will need tow it to a shop to fix this. I can't believe I've been driving around like this for 2000 miles. The previous owner gave me all his service docs and he complained about a strong fuel smell, but none of the Porsche techs detected any issue.
Old May 22, 2010 | 03:20 PM
have that oil looking stuff checked out as well... maybe thats old and the fuel covered it.. but from the pic that looks like oil... spray it with brake clearer once your fuel is taken care of and see if it comes back...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 22, 2010 | 11:10 PM
legendr34's Avatar
yea, I did that, the oil is really caked on there though. but I'm pretty sure there is no oil leak now, maybe from the past perhaps!
Old May 22, 2010 | 11:11 PM
legendr34's Avatar
Yes, it is the return line. If you look on the left side of the engine you will see a gold cad plated steel line. This line runs under the left intake.
Kevin, do you know if it's very difficult to replace this line?
Old May 23, 2010 | 06:10 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Requires dropping the engine, unfortunately.
Old May 23, 2010 | 07:47 AM
jpflip's Avatar
IMHO I think this line replacement doesn't require dropping the engine but instead lowering the engine. This seems to be line # 15 which is not too long and the other end of the fitting looks like located in the engine compartment. Be careful when you order the part because MY01 and the other MY looks different. If you look at the pics you will see the line running behind the alternator under the oil filter. I can see a couple of clamps. Probably not an easy job.... Here you will found the instruction to lower the engine from "rolfjahn" https://www.6speedonline.com/forums/...tt-engine.html
ID:	124334   Click image for larger version
Old May 23, 2010 | 09:20 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
yikes, yea may be possible to do by lowering. but looks like part of the #15 hose is hard piping. Not going to be easy and lots of stuff has to come out. With the right tools, man hours to drop the engine's probably going to be less than lowering to get that stuff out. one way to lower the cost is spread the labor over other maintenance/preventative/mods...
Old May 25, 2010 | 05:55 PM
legendr34's Avatar
Thanks for the advice guys, thanks for the clear photos Jpflip!
I dropped my car off at the local dealer and they said the part was $170 and the labor was over $3000
Am I able to DIY dropping the entire engine?
Old May 25, 2010 | 08:29 PM
Mad Ness's Avatar
you'd need a car lift that allowed clearance to drop the engine + special tools ... and of course know how. Wouldn't recommend it unless you knew exactly what to do or someone that did to help. May be use this as an excuse to mod/maintain a bunch of other stuff? https://www.6speedonline.com/forums/...ssion-out.html
HotRod
Sep 10, 2015 07:17 PM
Fester
Sep 8, 2015 09:35 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Because_R4CEC4R
Aug 23, 2015 08:53 PM
