Tune Questions: Greddy Settings, etc
Old Jun 16, 2010 | 09:28 AM
NVRENUF's Avatar
NVRENUF is a splendid one to beholdNVRENUF is a splendid one to beholdNVRENUF is a splendid one to beholdNVRENUF is a splendid one to beholdNVRENUF is a splendid one to beholdNVRENUF is a splendid one to beholdNVRENUF is a splendid one to beholdNVRENUF is a splendid one to behold
So I have a protomotive 24/18 car. Todd K. is helping me out and re-tuning for 104 Octane Fuel, etc. It has really woken the car up. It was very conservatively tuned with no timing before. I am a total beginner and just want some second opinions.
I have struggled getting up to the desired 1.2 bar boost. Been playing around. 1 observation. My dash boost reading shows .1 - .2 higher than datalogs thru Durametric show. Is this common?
Greddy Profec B. Here is where I am now. I've studied on here and haven't seen many people having to go as I am to get the desired boost. I am concerned, but do I need to be. These are the settings and what I achieved:
Set 58%
Gain 35%
Set gain .9 bar
Overboost 1.3
Overboost ret 10%
Last boost val.
Last boost ON
Max boost reached 1.0 bar
So it looks like I will need above 60% initial set to achieve 1.2 bars. I will lower the Gain quite a bit, but boost wasn't max until quite high in the RPM range at setting of about 18%.
Thoughts: Im just nervous that 60% initial setting is so high.
Old Jun 16, 2010 | 10:30 AM
unvmy996's Avatar
seems that the 58% is a bit high but then again... its hot where you are so that makes a big diff , i have to raise mine considerably when the weather jumps from 70 to 95 ..
an ya the dash gauge isnt the most accurate.
Old Jun 16, 2010 | 10:33 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
58% is a little high, I am at 38% @1.25 bar WOT. I have a lot of supporting mods with the k24/18gs however.
Have you adjusted your wastegates and done a boost leak test?
For that matter who installed the greddy, was it connected correctly?
The dash is slow and inaccurate for boost. Use the greddy or datalogging.
Tom
Old Jun 16, 2010 | 11:00 AM
jhuang25's Avatar
jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !jhuang25 Is a GOD !
I would start at 1 bar and work your way up. These were my settings on Greddy Profec, K24/18G... from there, just turn it up slightly as you go.
1 bar
35% main setting
10% gain
0.6 bar set gain
1.2 bar overboost
10% overboost return
ON Last boost
Old Jun 16, 2010 | 11:37 AM
NVRENUF's Avatar
Oh, and at 5500' altitude, and ran last datalog at about 82 degrees F. I know Greddy is installed correctly, and no leaks. Unless something changed in last couple months, which is a possibility. Don't think so though.
Old Jun 16, 2010 | 12:14 PM
tvurt's Avatar
So the issue is you are only getting 1 bar of boost, max?
After checking codes i would go in this order:
1) is your tune set for an EBC?
2) greddy set up physically properly?
3) Wastegate adjustment, do you have upgraded 1 bar wastegates?
3) boost leak . . .
What other mods do you have? like injectors FPR ect.
Tom
Old Jun 16, 2010 | 12:19 PM
NVRENUF's Avatar
So the issue is you are only getting 1 bar of boost, max? I can get 1.1 bar, and think I can achieve 1.2 bar, but 1.1 takes 60% initial setting or so.
After checking codes i would go in this order: No codes.
1) is your tune set for an EBC? Yes
2) greddy set up physically properly? Questionable, but Im positive. It was setup before I got the car and Im confident it was correct.
3) Wastegate adjustment, do you have upgraded 1 bar wastegates? yes
3) boost leak . . . may need to check. It was good when purchased 500 miles ago.
Protomotive K24/18G Hybrid Turbos Clipped and Ported
Protomotive Intake-Plenum, Throttle body, Maf, Etc...
Protomotive Tuned ECU
Protomotive USB + PC Software
Fabspeed Stainless Headers
Fabspeed Hi-Flow Cats
Fabspeed Muffler
BMC Air Filter
Bailey’s DV Valves
5.0 bar Fuel Pressure Regulator
Denso Spark Plugs
Protomotive 3" Crossover Exhaust
OEM Porsche GT2 Intercoolers
Old Jun 16, 2010 | 01:33 PM
unvmy996's Avatar
well im sure the altidude and weather have something to do with it.. i would email todd k and ask him he will give you exactly whats up.
btw i would scrap those gt2 intercoolers they are junk especially beeing in a hot enviroment i would upgrade to some beefy ones.
Old Jun 16, 2010 | 01:49 PM
tvurt's Avatar
You should have no problems maintaining whatever boost your tune is set for with those mods. You should have the opposite problem, keeping the boost down
Were your wastegate actuators set for your current altitude? I would start with a boost leak test @ the intake, then re adjust your wastegates. Big boost leaks usually code tho . .
Tom
fwiw i blew a hose off my drivers intercooler output on my way home yesterday . . . it happens....
Old Jun 16, 2010 | 01:56 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
I have k16/26's zero clearance (a special set of Kevin's UMW) with the 1bar wastegates and it takes me nearly 70% on the Greddy to get 1.2bar
Old Jun 16, 2010 | 02:45 PM
Szpet's Avatar
Szpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud ofSzpet has much to be proud of
I have the Tial A28 turbos with 1bar wastegastes and Protomotive tune.
I set the Greddy to 59% to get 1.25bar.
Old Jun 16, 2010 | 03:07 PM
NVRENUF's Avatar
Im ahead of you on that one Just waiting for pocketbook to catch up
Good to know that you both run higher numbers. Im new to the hairdryer concept, especially when speaking bars vs. lbs. etc etc. I was just concerned. Todd K. has already re-assured me everything is well and good, just wanted education and other opinions. Im like a sponge trying to absorb all I can.
Old Jun 16, 2010 | 03:54 PM
996ttalot's Avatar
996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute
Set 58%
Gain 35%
Set gain .9 bar
Overboost 1.3
Overboost ret 10%
Last boost val.
Last boost ON
Assuming the car is okay I just think your settings are wrong.
1 bar WG are 0.8 bar. So you have 58% = 1.264 bar.
But you have gain set to 35% - way too high - it should be between 5% to 10% - this allows the boost to be consistent, so that you do not see a drop off. So with 35% what is happenning is that you are probably spiking. If that is the case, then you will trip the 1.3 bar limit, and it will reduce 10%, so back to 1.17.
Your set gain is a little high = set that to 0.8bar.
Run this and see what you get. The simple way is to run without set gain or gain, with the 58% and see what your maximum bar is.
I run two modes on my car (k24/20g)
LO
50%
5%
0.8
1.4
10%
This gives around 1.2 bar.
HI
74%
8%
1.0
1.55
10%
The latter normal gives me a consistent 1.4 bar.
Old Jun 16, 2010 | 07:50 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
in my 997TT with GT30
set : 45%
gain : 20%
setgain : .8
warning : 1.4
limter: 10 %
it reached 1.3
are the EBC settings Affect to throttle response ??
Old Aug 12, 2010 | 10:30 PM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
I just want to know where or HOW you got that decal! I have been bugging Tod and Cynthis for three year 4 that very same script logo..Nada. Zip. Zilch!
LO
50%
5%
0.8
1.4
10%
HI
74%
8%
1.0
1.55
10%
