greddy boost control
Old Jul 5, 2010 | 11:12 AM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
what greddy boost contrill is best for a moded 996tt???
Old Jul 5, 2010 | 11:27 AM
unvmy996's Avatar
greddy profec , you just cant add it to you existing setup since you dont have one. your going to need a specific tune for it.
Old Jul 5, 2010 | 11:33 AM
rats !!!! will it work with giac???
Old Jul 5, 2010 | 11:39 AM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
greddy profec b spec ii is the newest version, comes in black as pictured. used in my supra, and worked well. allows low and high boost settings. just 3 adjustments; set boost, boost level and gain. 3 are correlated so for example if turn up gain, must dial down boost level to get a balance. also has peak boost display, as well as an over boost warning and limiter that allows a % boost cut if max exceeded.
Old Jul 5, 2010 | 11:44 AM
mad do i have to remap?? and how much it this item thanks steve
Old Jul 5, 2010 | 11:52 AM
yes you need a map to get some values out of the way... there are 2 n75 maps and 2 boost maps... one target and one actual... all that needs to work together...
how much boost are you running now?
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 5, 2010 | 11:55 AM
Mad Ness's Avatar
pretty sure you do. i know with softronics and proto this is the case. think part of the reason is cos the stock n75 boost solenoid is either deleted or aftermarket solenoid added to the system. and may be the 1.3boost limiter has to be removed but Im only guessing.
vivid is selling it for 418 http://www.vividracing.com/catalog/g...ack-p-385.html
think that's market for these in the US.
Old Jul 5, 2010 | 12:03 PM
thanks mad !!! markski was at 1.3 until i installed a new bv, am thinking i have a leak as my drive to workshop came on. checked the code and it's the air injectors both sides. thought this was only in effect on warm up mode thanks in advance steve
Old Jul 5, 2010 | 12:06 PM
something is up.... get it pressure tested...
9.66
click to view
Old Jul 5, 2010 | 01:17 PM
vividracing's Avatar
You can run a EBC without retuning the car, but if you hit 1.3 the throttle plate will close so that is why when we do EBC we dont just disconnect the stock boost solenoid, we deactivate its functions.
NC 996TT
Mar 23, 2023 06:19 AM
davetherave
Bentley
Sep 11, 2015 04:15 AM
