P1109 is back!!!
Old Jul 7, 2010 | 10:55 AM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
P1109 is back!!!
The dreaded p1109 code is back!! First I cleaned the maf then replaced it with a brand new one. I also replaced the throttle body. I did a boost leak test as well. I'm running out of options
At idle the rev go's up and down and eventually cuts off completely. The only code on durametric is p1109.
P1109: Input variables, charge measurement above limit
Possible fault cause:
heavily soiled throttle
Throttle adjusting unit faulty
MAF faulty
My setup is a GT700 with HMAF.
Any thoughts would be appreciated!!
Old Jul 7, 2010 | 11:11 AM
XLR82XS's Avatar
Did you call EVO? Maybe the can shed some light on this.
Old Jul 7, 2010 | 11:28 AM
Yes, Todds on tour and Rods on vacation.
Old Jul 7, 2010 | 12:05 PM
XLR82XS's Avatar
Know about Todd but didnt know Rod was gone. Sounds like it could be a vacuum problem. ???
Old Jul 7, 2010 | 01:30 PM
tone01's Avatar
tone01 is infamous around these parts
intake
i had the same problem mines was that pipe behind the intake that runs behind the motor. sounds you have a loose pipe connection some wear
Old Jul 7, 2010 | 02:52 PM
Here is the youtube vid with the car just shutting off at idle
http://youtu.be/66wWqI1m5FU
disconnect the maf harness and if the cars runs the same then its the maf....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 7, 2010 | 03:03 PM
ttboost's Avatar
Hunting at idle and stalling is USUALLY associated with a vacuum leak. MAF's on these cars are evil... Smoke test?
Old Jul 7, 2010 | 03:18 PM
Will be checking the fvd inlet hoses to the turbos... Hopefully this is the issue!
Old Jul 7, 2010 | 03:20 PM
Yes did this approach when we checked for boost leak and replaced the H-maf with a brand new one.
Old Aug 2, 2010 | 11:12 PM
So did a boost leak test & smoke test, brand new hitachi maf, brand new o2 sensors all 4 of them, brand new throttle body and still p1109 input variable charge and hot film maf.
I'm all out of ideas!!
Old Aug 3, 2010 | 09:37 AM
Mr swed's Avatar
Mr swed is infamous around these parts
Just an idea
Have you checked that the connector plug and wires to the MAF is ok? I think there is a description on how to measure the wires in the electric manual. I had a similar problem with my 993 it almost drove me mad till I found the problem with a bad wire in the connector.
best of luck
Old Aug 3, 2010 | 09:58 AM
Very good suggestion and yes I checked the wires since few people had that problem.
Originally Posted by Mr swed
Just an idea
best of luck
Old Aug 3, 2010 | 10:24 AM
Slider's Avatar
I had a boost hose blow off and give me a MAF code (P0103 as well as 5525, ABS and PSM). Idle was as described by the OP right up to the engine cutting out. I removed the connector to the MAF and the engine smoothed out perfectly at idle. There was nothing wrong with the MAF at all - just reconnected the boost hose and everything was back to perfect.
w00zie
10
Dec 26, 2022 11:09 AM
97GtsMonster
Nov 17, 2015 12:38 PM
raaspaza
Bentley
11
Sep 9, 2015 08:51 AM
cby1
Sep 1, 2015 10:25 AM
orbelo
Aug 30, 2015 12:26 PM
