Just Got My 996TT! Wheel/Tire Question
Old Jul 19, 2010 | 02:55 PM
@l996's Avatar
@l996 is just really nice@l996 is just really nice@l996 is just really nice@l996 is just really nice
Hi Guys,
I just picked up a 996TT last weekend. My friend offered to sell me his BBS LM's from his 996 C2 for a ridiculous price. I bit and bought the wheels from him. The front's are 235/35/19 and the rear's are 275/35/19. The rear wheel is 10" as opposed to the stock 11" wheel width. Is that going to be an issue? Can I just change the 275's on the rear wheel to 295's and the 235's to 225's to retain the stock tire width's? What are the effects of running improperly sized tire ratios? I've been reading on the forums and that seems to be a huge no-no.
Old Jul 19, 2010 | 03:00 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Wheel spacers in the back may be needed to fill things out. I'm sure others will chime in on the tires also.
Old Jul 19, 2010 | 03:17 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Well, you should have posted this ?? before pulling the trigger no? LOL...
The bummer is that you went from an 11" to a 10", depending on the off-set you have on the BBS will determine the spacer kit you'll need for the rear, I would estimate 17mm - 25mm might help to push the wheels out a bit.
The fronts should be fine, I'm sure around 45et....
The tires in front are fine at 235/35/19, the rears are an other issue as in order to maintain something close to factory you'll need a 275/30/19 or 305/25/19 or 315/25/19 for your specific vehicle.... Now we all know that getting a 305/25/19 or 315/25/19 to fit a 10" wheel is going to be HARD!!! You cannot use a 295 since you went to 19", it would cause you to gain an full-inch and that cannot be good...
If you have other questions you can call me or PM me for help....
You may need to get a set of spacers for the rear and stick with the 275's.....
-Eli
Old Jul 19, 2010 | 03:28 PM
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
Running 275 rears on a turbo is a bad idea. Yea the spacer will make it look better, but dos nothing to address the traction and safety issues.
Old Jul 19, 2010 | 04:16 PM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
Might be better to sell the wheels to a NB 996 owner and use the money made to pick up another set. it's not worth possibly blowing your front differential
Edwin
Old Jul 19, 2010 | 05:01 PM
ETW 360's Avatar
ETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant futureETW 360 has a brilliant future
I wouldnt put 10" wide wheels on the back unless its for snow tires
Old Jul 19, 2010 | 05:54 PM
BOXER4's Avatar
BOXER4 is infamous around these parts
hmm....not to use a 295 huh I think I may have a problem then.. I have 235/35/19 fronts, and a 295/30/19's on 19x11 rear wheels is this bad?? if so LMK
-Eli
Old Jul 19, 2010 | 06:12 PM
dfwerdoc's Avatar
dfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud of
sell the wheels ..... if you're doing 19 inch wheels stay with 315/25/19 in the back. do a search and you'll see how there are very few if any options.
Old Jul 19, 2010 | 06:33 PM
@l996's Avatar
Thanks for the info guys! I got a great deal on the rims with tires. $1600. I'll probably just sell the rear's and get 19x11's. What offset should I get so I won't have to use spacers?
Old Jul 19, 2010 | 07:26 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
you might try to get a set of barrels for the rears that work with the proper offset and width.
Old Jul 19, 2010 | 07:43 PM
ard's Avatar
ard
a huge no-no.
Your tires ARE NOT MATCHED IN DIAMETER for a AWD 996 Turbo.
The fronts are 25.5", the rears are 26.6:- these will destroy your differential.
If the rears were 275/30-19 you would be OK (a5 25.6")...well, they'd be too skinny, but atleast not damaging.
And why the 19" rim? Performance is lowered.
Welcome!
A
PorscheSocieta's Avatar
PorscheSocieta is infamous around these parts
as already recommended. sell and get an appropriate set for your Turbo. u probably got excited when you saw the BBS wheels, don't blame u, but no sense in trying to make them work on your car.
Old Jul 19, 2010 | 09:22 PM
sid350's Avatar
sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !sid350 Is a GOD !
If he's really your friend:
1. He would take the wheels back
2. He shouldn't of sold you wheels in the first place
Old Jul 19, 2010 | 09:36 PM
TekNiC3's Avatar
TekNiC3 is infamous around these partsTekNiC3 is infamous around these parts
If I remember correctly, the closest size is 19x11 +50
I would run a 15mm spacer with that set up.
Old Jul 19, 2010 | 09:59 PM
legendr34's Avatar
legendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud of
you can get new barrels too
