which methanol injection kit to go with
Old Aug 18, 2010 | 10:45 AM
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
not sure which one to go with. AEM or Aquamist hsf 1? i like all the safety features aquamist offers but do i really need all that? as long as i have the low level indicator, i should be fine but the price is also an issue. AEM does not have all the features aquamist has but is it worth all that?
Old Aug 18, 2010 | 11:04 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Aquamist HSF3.
Old Aug 18, 2010 | 12:14 PM
MorePSiTehBett4's Avatar
MorePSiTehBett4 is just really niceMorePSiTehBett4 is just really niceMorePSiTehBett4 is just really niceMorePSiTehBett4 is just really nice
without ecu based failsafes(don't know as much about the porsche ecu as other ecu's) and if there is the availability of e85, I would say no meth injection. That's for another thread though, but if you must aquamist from the UK is king.
Old Aug 18, 2010 | 12:40 PM
After doing some research I am planning on doing the Aquamist HFS6
#TeamAIM
Old Aug 18, 2010 | 03:03 PM
dixie's Avatar
dixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to alldixie is a name known to all
The new Perrin kit should also be very good.
http://www.perrinperformance.com/pro...tem?category=4
Old Aug 18, 2010 | 03:22 PM
Tony@epl's Avatar
Unless you track your car ALOT, you can use the 3 and achieve the same results.
Old Aug 18, 2010 | 03:23 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
what is the difference between the HSF 3 vs 6? larger tank??
Old Aug 18, 2010 | 05:30 PM
ttboost's Avatar
What if a line bursts? or gets melted because of a bad install? or anything OTHER than low level? ...melted engine, thats what...for a couple bucks. (Aquamist also has a flow meter) Detonation will kill your engine faster than that tank will drain down so your low level indicator will shut it off. Do yourself a huge favor and just buy an Aquamist kit. Better to have too much than not enough...Mine has been installed for way over a year and I haven't touched it and it works MINT!!!
Old Aug 18, 2010 | 07:14 PM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
Can one use 100% meth with the aquamist hfs3 kit? everyone I know uses it for cooling 50/50 mix.
Old Aug 18, 2010 | 07:16 PM
ttboost's Avatar
I have an older HFS-1 kit and have ONLY sprayed 100% VP M1 meth through it, except for a few 50/50 dyno pulls.
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I have used both AEM and Aquamist with good results. If you are interested, I have my old AEM kit FS, PM me.
Old Aug 18, 2010 | 08:44 PM
cjv's Avatar
cjv
Moderator
Strange. E85 is good to about two bar. We are running a lot more than two bar with E85 and we need Aquamist with the E85.
Old Jan 23, 2011 | 07:03 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
I'm in a search for the best and most safe straight Methanol kit, i just uninstalled my AEM kit which fail after using straight methanol
Old Jan 23, 2011 | 04:29 PM
ttboost's Avatar
Aquamist HSF.
Sales@RSW
Sep 3, 2015 09:34 AM
orbelo
Aug 30, 2015 12:26 PM
Aug 21, 2015 06:34 AM
