Flash problem
Old Sep 10, 2010 | 09:34 PM
DrF's Avatar
DrF
DrF is infamous around these parts
Flash problem
I recently purchased an EPL flash for my 05 TTS. Unfortunately I can't get it working. Everything initially proceeds smoothly. Car recognized. Flash downloaded. "Programming" progress bar takes 5-10 minutes to complete. The next step is "writing program" with a new clean progress bar and an immediate error:
Unable to write flash. Details: ”An error has occurred executing an operation on the ECU.”.
I've tried downloading a new flash and using a different, fully charged laptop. My battery is 1 month old and installed by the dealership; It shows >12v with the key in run position. Only thing I haven't tried is the battery charger, but I have low hopes of success with this.
EPL did wonder if the car is already flashed. My usual max bar is 0.8 with a one-time 1.0 on a very cold morning. The previous owner was a Porsche dealership and the car was a lease.
Any other ideas?
Old Sep 10, 2010 | 09:39 PM
NOLA911's Avatar
NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !NOLA911 Is a GOD !
Have you talked to EPL yet?
They have seen it all and probably know exactly where the issue lies
Old Sep 10, 2010 | 09:59 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Double check the connections. I had the same issue and it was my usb port at my laptop not connecting correctly. Once I figured that out, only 5 minutes or less and it was flashed.
Old Sep 10, 2010 | 10:14 PM
DrF's Avatar
DrF
EPL suggested a new laptop, trying a fresh flash, and using the charger.
Only thing I haven't tried is the charger.
Old Sep 10, 2010 | 10:15 PM
DrF's Avatar
DrF
The cable is recognized on both laptops, in different USB ports. Still get the same error on the same spot in the flash process.
Old Sep 10, 2010 | 10:19 PM
Nikolas's Avatar
It was for mine also, the cable just came loose as my USB ports were on the right side of the laptop stretching the cable. Once I placed the laptop, oddly enough in my lap, it loaded no problem.
Old Sep 10, 2010 | 10:46 PM
Screamin911's Avatar
Screamin911 has a spectacular aura aboutScreamin911 has a spectacular aura about
I had that exact problem when I tried uploading my EPL flash to my Turbo a couple months ago. Took 3 different laptops before I finally got one to work. Try another laptop. I know its a pain but thats what did it for me.
Old Sep 11, 2010 | 01:44 AM
DrF's Avatar
DrF
A third laptop. I only have two. Any thoughts about what the difference was between the successful laptop and the others? Certain services or programs running or not running?
Old Sep 11, 2010 | 10:04 AM
ard's Avatar
ard
My guess- just a guess- is that it will be buried in the USB hardware/driver routine. Try and find a different mfg. (ie not just two different Dells.)
To Scremin911- what MGFs did you try, which worked???
GL
A
Old Sep 11, 2010 | 11:56 AM
Nikolas's Avatar
I loaded mine on a brand new HP laptop. Again, I got the same errors. It recognized the usb device, but when I started the flash process the cable came just slightly disconnected. Are you stretching the cable from the OBD port to the laptop in any way?
Old Sep 11, 2010 | 12:08 PM
willieboy's Avatar
willieboy is a jewel in the roughwillieboy is a jewel in the roughwillieboy is a jewel in the rough
When I did mine recently it went flawless. Two year old Toshiba laptop on a charger in the garage. Followed the directions and no problems. I think the cable should be a little longer but other than that, everything went as directed. Did I mention I love my EPL flash? Once you got it done, Let us know how you like it
Old Sep 11, 2010 | 04:42 PM
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
Mine worked flawlessly.. Dell 610 Laptop, Windows XP....
Old Sep 11, 2010 | 05:05 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
put a low amp charger on the car battery
Old Sep 11, 2010 | 05:15 PM
Forget everything... Stop....
Send the ecu to Tony... have him bench flash it... overnight shipping $20... new laptop $600... new battery $160... etc etc...
If you have a Giac flash, they encrypt the ecu, and usually cannot be flashed in car...
just a thought... but I would take it out and send it.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 11, 2010 | 05:17 PM
bbywu's Avatar
I think Marek hit the nail right on the head.
