Fault codes after fitting 5bar fpr
Guys, my brockway is showing some fault codes... car has been sat up for last 3 mths sorting clutch issues & having a 5bar fpr fitted, and now sorted I drove it 70miles home and shut it off. No fault codes during journey (according to the brockway), so parked for a couple hours and when restarted it, I had no volume from the PCM2.1's radio so had a look at the brockway and it showed the following codes:
P185
P3884
U21539
P185 I can see relates to "Fuel Temp Sensor 2 circuit" - would this related to the 5bar install ?
Can't find any info on the other two codes.... any advice/thoughts appreciated !
P185
P3884
U21539
Thats strange... so when you check your stored fault codes it shows 0 but durametrics shows a number of them ?
Maybe send it back and have it checked by Brockway?
I need to have my car plugged into PWIS or durametric but can't do it for a few days hence trying to self-diagnose the issues now...
Has'nt been done yet no but it is scheduled for it.
Previous to having the 5bar fitted it was running at 13-13.3 AFR above 6500rpm, below that it was mid 12s... i.e. a bit lean, hence added the 5 bar
Following install, on the previous tune, my AFR's are now 11.8-12 @ max revs in 5th gear, i.e. 155mph ish... thats more where I should be but at the same time its thrown the fault codes above !!
target afrs are high 11s on a stock fuel map... so something is going on...
2001 996TT 3.6L and stock ECU
Very kind offer Neil - appreciate the gesture my friend !
Originally my file was running a tad rich, 11.2 @ max revs, so I requested a slightly more aggressive file and then arranged the airfield day which Ken et al attended where I logged the car, and above 6500rpm in 4th & 5th, it was slightly over 13's, which is a tad lean. Hence I requested that I have a 5bar installed, which happened, but I haven't got the re-tune for it yet, so am still running my 3.8bar file.
According to my brockway, now red-line in 5th gear is giving me 11.8-12 AFR so clearly the 5bar has richened me out, albeit clearly its not optimised yet.
Would the fault codes be related to the 5bar install... specifically the P185 ?
Thx
Ok thanks for the clarification....
you need to ONLY trust the durametric... forget the brockway...
who's doing the remapping?
on a side note.. I found a few euro tuners to run the cars very rich... odd... cause these care run best at .82 lamda...
Mark, I'm running an X50 + flash + Milltek 200 + Ruf Inconel Headers.
Thx
Thx
