Pss10 settings - street only
Old Sep 12, 2010 | 03:42 PM
tws_andrew's Avatar
tws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to alltws_andrew is a name known to all
Where do you guys like yours? Mine just went in and are on 5/5 but it seems a little soft to me especially after coming from my GTR on KWs. What do you guys recommend?
Old Sep 13, 2010 | 07:05 AM
fdorn's Avatar
fdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud offdorn has much to be proud of
I run 5 front 6 rear on the street (8 front 9 rear or 10 rear on the track).
Old Sep 13, 2010 | 07:48 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I used to run 5/6 on the street; it was a little soft. I now run 7/8, the car is more fun to drive.
Old Sep 13, 2010 | 12:03 PM
vividracing's Avatar
Run the front about 3 and the rear about 6. The front of the 996TT is bouncy cause there is no weight. The rear is heavier. I liked this setup.
Old Apr 9, 2011 | 06:32 PM
howardm50's Avatar
howardm50 is infamous around these parts
Q?
Guys -- I was under the impression the smaller numbers were supposed to be stiffer; is that not correct?
Also, to get to the rear adjuster ***** I understand I need to remove the rear carpet inside... any techniques on doing this? I have the bose subwoofers in the back and I can't see an easy way to pull the back deck up.
Input appreciated - itching to play around with my new PSS10 settings!!
Old Apr 9, 2011 | 07:21 PM
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
The higher the number on the pss10's are stiffer and the opposite for pss9's. I run my pss10's 6 fronts and 8 rears
Old Apr 29, 2011 | 11:15 PM
howardm50's Avatar
bump... any advice on getting to the rear to adjust settings? TIA!
Old Apr 30, 2011 | 04:24 AM
_gez_'s Avatar
_gez_ is infamous around these parts
If you've got the Bose subwoofer you have to remove it. To do so prise off the plastic ports on the subwoofer to reveal a screw under each side. Undo the screws and the sub will pull forward. There is a plug for the wiring at the rear of the sub. Unplug it and remove the sub.
From then on it should be obvious - you lift the carpet to reveal the top of the shocks (not sure if there is a cover over the shocks - haven't adjusted mine yet!).
EDIT: Found this link in my history - should help. http://sharkwerks.com/porsche/techni...2-and-gt3.html
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
The Oss
Aug 24, 2015 08:19 PM
pwdrhound
Aug 20, 2015 05:54 AM
