How good is the ECU?
Old Sep 30, 2010 | 07:28 AM
bob'5's Avatar
bob'5 has a spectacular aura aboutbob'5 has a spectacular aura about
How good is the ECU at adjusting for fuel changes?
Could it cope with say 10% Meth added to the tank or maybe even 20% Meth?
Used to put 10% Meth in the Impreza for drag runs without map changes.
ECU is currently flashed for normal pump fuel.
Old Sep 30, 2010 | 07:36 AM
ttboost's Avatar
When you say "adjust", what do you mean? If you run meth or race fuel on a pump gas tune, all you are doing is eliminating the chance of timing retard.
Old Sep 30, 2010 | 07:42 AM
bob'5's Avatar
Adjust/learn to the fuel type.
Meth leans out the AFR.
You see many 996TT flashes sold as them being able to learn/adjust to benefit from using race fuels without needing dual maps.
Old Sep 30, 2010 | 08:31 AM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Hey bro, who you calling a retard?!?
Old Sep 30, 2010 | 09:40 AM
gt2rs6's Avatar
gt2rs6 has a spectacular aura aboutgt2rs6 has a spectacular aura about
he said add meth to the tank!?! as in fuel tank?? ttboost has meth injection.. can you add methanol right to your fuel tank? thats what you used to do to the sube?? dosent seem right
Old Sep 30, 2010 | 09:45 AM
bob'5's Avatar
Yes, straight to the tank.
Old Sep 30, 2010 | 10:01 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
bob'5
Does your ECU is mapped ?? or flash ??
Old Sep 30, 2010 | 10:32 AM
bob'5's Avatar
Current one is flashed I believe.
Might get the KS3 Knock Analyser connected up and see what % meth the car likes if there isn't any data on here.
Old Sep 30, 2010 | 11:25 AM
rdss's Avatar
That's a good idea.
Old Sep 30, 2010 | 11:30 AM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
The ECU can adjust fuel trims 15-20% if I remember correctly. I don't see any reason for doing it though. My thought is if it is going to make more power it's going to do it because it is lean, because you know the saying "Lean is mean!". If you are relying on the ECU to adapt and add more fuel I don't see how you are going to gain any more power.
Old Sep 30, 2010 | 12:10 PM
unvmy996's Avatar
LMAO are you for real ?
Old Sep 30, 2010 | 12:28 PM
ttboost's Avatar
Offended???
Old Sep 30, 2010 | 12:29 PM
ttboost's Avatar
Might get the KS3 Knock Analyser connected up and see what % meth the car likes if there isn't any data on here.[/quote]
I can't imagine what adding Meth to the fuel tank is gonna get you, other than a little knock protection...??? Install a meth spray kit and tune for it. It did drop my A/F by about a point, but I also picked up massive power with it too...
Old Sep 30, 2010 | 12:46 PM
996ttalot's Avatar
996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute996ttalot has a reputation beyond repute
When I have run different fuel e.g. 104 race fuel against 99 std, I away reset the adaption values by disconnecting the battery for 20 minutes. Otherwise you can waste half a tank of fuel while the car adapts. If you reset, then it adapts pretty much instantly. It is to do with the STFT and LTFT.
Anyway that was what I was told to do, and it seems to work fine doing it this way.
Old Oct 1, 2010 | 07:27 AM
bob'5's Avatar
Running 20% meth in tank can give gains as good as race gas. The knock protection isn't as good though, but meth in tank is the choice for many in the UK here with Subarus.
My question may have been better put to ask: Can the ECU adjust to take advantage of higher octane fuels?
Vivid R imply that the ECU will:
ECU tunes by Softronic or designed for either 91 or 93 octane. The addition of race gas or those internationally, the ECU will adjust to the change in octane accordingly.
If some ECU mappers could share their views it would be highly appreciated.
