ATS/Carbonetics triple disk clutch problem
Old Oct 3, 2010 | 09:03 PM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
Unhappy ATS/Carbonetics triple disk clutch problem
Recently I installed ats/carbonetics tripple disk clutch in my 996tt. followed everything per instructions as fas as stacking the plates in correct order and torquing the bolts properly.
After the install the car, engine running, would not shift into any gear. With engine off it shifts normal leading me to believe something is up with the pressure plate. Probably not fully disengaging from flywheel.
The slave is properly bled, all correct 964RS required components are installed.
Please help, as I am not sure what could be causing this issue.
Thanks in advance.
Old Oct 4, 2010 | 12:28 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I have the same clutch and was advised to have a an experienced installer install the clutch. i would take it to the dealership and have them take a look at it.
Old Oct 4, 2010 | 01:01 PM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Calling the manufacturer might be helpful at this point too. Good luck.
Old Oct 4, 2010 | 01:32 PM
He is a P car certified mechanic... Ive had one of the very first ones 4 years ago... not easy bit doable... I think they got something screwed up in the parts....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 4, 2010 | 03:58 PM
Ms4cd's Avatar
Thanks for the advice, we are still trying to figure things out.
Appreciate the input.
Old Oct 6, 2010 | 11:28 PM
Tim941NYC's Avatar
Ms4cd,
I put mine in today. Kind of the same problem. I am using the gt2 fork and slave. I think the angle of the fork has changed a little bit. I did not check the height of the old vs triple setup but I think my fork is hitting the bell housing and stopping there not letting the fork move farther.
Old Oct 7, 2010 | 08:06 AM
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
we're using all the 964rs parts requested and still having the same problem. the gt2 slave and fork should be fine as long as you're using 964rs throw out bearing and all the other suggested 964rs parts. i sent mine back to carbonetics to see if they see anything i don't. just waiting for an answer
Old Oct 7, 2010 | 09:29 AM
robertp's Avatar
It's an alignment problem when you installed the clutch. Have a guy do the install that installs clutches all day long. The dealership did mine in 3 hours and changed the tranny oil too. It is pricy but the install is correct.
Old Oct 7, 2010 | 10:32 AM
Ms4cd's Avatar
Thanks for your input.
This job is being done by a tech, with assistance of a PCA national tech chairman. We strongly believe it's the part since the car will not shift no matter how the clutch is installed/aligned.
Old Oct 7, 2010 | 11:51 AM
robertp's Avatar
Good approach. I had the clutch installed ove two years ago and it is rock solid. Who is doing the install, Kasper? If you need any assistance over at ATS I can make a call for you.
Old Oct 7, 2010 | 11:42 PM
Tim941NYC's Avatar
Robertp,
3 hours not on a 996 turbo! 996 N/A maybe.....
Old Oct 8, 2010 | 12:00 AM
Tim941NYC's Avatar
I talked with them today and and they told me to cut 15 to 20mm out of the push rod on the slave. it was a lot of work to get it right. The tiltons I have installed in the past were a breeze to install and you loose that bs pull type set up. you put the hydraulic slave/ throw out bearing in and call it a day. I tried a new to me product that others rave about plus save a few bucks and instead I spent hours and hours trying to get it to work.
Mine is working now but is slipping like crazy, also I was told 800 miles to break in (Tilton good to go right out of the box). I hope not.
Old Oct 8, 2010 | 03:43 PM
pinoy911tt's Avatar
thanks for all the help today, bud
Old Oct 8, 2010 | 06:01 PM
Tim941NYC's Avatar
Anytime! Hope it works out for you, with your build...
Old Oct 8, 2010 | 06:08 PM
pinoy911tt's Avatar
Originally Posted by dick_997
I need a clutch and trying to decide. I know the tilton is top of the line but I can't swing 6500+ for a clutch. The ATS is pushing it as it is. So would love to hear the outcome. Tim941NYC, is your clutch slipping due to power level or just that it isn't broken in yet?
i'll let you know what happens next week when i get the other pressure plate they're sending.
