Spacer widths...recommendations?
Old Oct 26, 2010 | 02:40 PM
SRISER's Avatar
SRISER has a spectacular aura aboutSRISER has a spectacular aura aboutSRISER has a spectacular aura about
Looking to add some spacers front and rear to fill up those wheel wells. Keeping the stock twists. My initial thought after measurement was 15mm. Anybody do anything different?
Old Oct 26, 2010 | 04:34 PM
Hogapalooza's Avatar
Hogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond reputeHogapalooza has a reputation beyond repute
I have 13mm in front and 21mm in rear. I run OEM twist as well.
Old Oct 26, 2010 | 04:47 PM
SRISER's Avatar
How are your wheel lining up?
Old Oct 26, 2010 | 04:56 PM
I'm not sure what you're asking. You can go out to 15mm on the front but I found some 13mms for a steal and went w/ them, 21mm is he max on the rear.
The wheels are right out on the corners but they aren't past the fender. That being said, the rears are out a little further then the fronts because of the wide rear end.
Old Oct 26, 2010 | 04:59 PM
ttboost's Avatar
I did 15 rear and 7 front...with stock size wheels...
Old Oct 26, 2010 | 05:03 PM
SRISER's Avatar
Sorry, I meant whether they are flush vertically with the fender. Appreciate the responses!
Old Oct 26, 2010 | 05:19 PM
ttboost's Avatar
Yes..my 15 and 7 are pretty flush with fender... rear more than front...see my avatar....
Old Oct 26, 2010 | 05:34 PM
Yes mine are flush. Like I said, 21mm w/ OEM wheels are the max in the rear. 15mm are the max in the front.
Anything bigger pushes the wheels out past the fender, anything less leaves them tucked under.
Old Oct 26, 2010 | 06:22 PM
SRISER's Avatar
Where in CT are you? We are moving up in Dec. Know any good indie shops around the New London area?
Old Oct 26, 2010 | 10:09 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
15mm all around
Old Oct 27, 2010 | 04:59 AM
ttboost's Avatar
I live in the other corner now (Fairfield County), but there are a few members here that live over that way...I can ask around...
Old Oct 27, 2010 | 05:50 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
some pics will help a lot guys, thanks!
Old Oct 27, 2010 | 06:15 AM
Here ya go.
Old Oct 27, 2010 | 01:31 PM
GMendoza's Avatar
GMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of lightGMendoza is a glorious beacon of light
Do you have to roll the fenders if lowered and run spacers?
Old Oct 27, 2010 | 01:56 PM
Kevganzon's Avatar
Kevganzon is infamous around these parts
I've seen guys run 15mm front/ 18mm rear lowered with no rubbing. I dont know about 21mm in the rear. I like the way it looks though
