help with gas sensor???
Old Nov 22, 2010 | 06:56 PM
jjc4scab's Avatar
jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !jjc4scab Is a GOD !
Red face help with gas sensor???
My friend has a turbo cab with a small issue......Is this common?
My car is in the shop. The valve in the gas tank is broken-it will not
> allow any gas to be pumped in because it senses it that the tank is full
> This is Second time in 4 months Išve had it in the shop for the same
> problem. They have to take the whole front end apart again (its all wheel
> drive). Its crazy! Have you ever heard of this? Last time they took it
> apart they also screwed up the PSM sensor so now that goes off every time I
> drive.
Thanks for lookin
Jim
Old Nov 22, 2010 | 07:42 PM
jdiesel's Avatar
jdiesel has a spectacular aura aboutjdiesel has a spectacular aura about
my turbo doesnt let me fill the tank it usually stops at 3/4s full. Is that the same problem you are having or can you not put any gas in? If its the same problem as mine then its pretty common cause I knew a few turbos with the same issue.
Old Nov 22, 2010 | 07:50 PM
raineycd's Avatar
I think most recommend turning the pump handle upside-down when putting in gas to get maximum input into the filler to trip the flap to open.
Old Nov 22, 2010 | 08:27 PM
jjc4scab's Avatar
I will email my friend with the ?
Old Nov 22, 2010 | 08:28 PM
jjc4scab's Avatar
seriously......wow ....never thought....will email my friend.....is this a common problem?
Old Nov 22, 2010 | 10:02 PM
jdiesel's Avatar
yea I dont even know how big the gas tank is yet cause its never filled up the whole way but I ve only had the car two months. My friend takes the nozzle out when it stops, then puts it back in and fills up, and again repeats when it stops. I usually fill up at a quarter tank so if i put in 8-10 gallons its good enough for me.
Old Nov 22, 2010 | 10:11 PM
TweakitTT's Avatar
TweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to beholdTweakitTT is a splendid one to behold
I had the same problem. Fix for me is lift the handle while filling up on gas. Always fills to max now.
Old Nov 23, 2010 | 09:51 AM
qvt408's Avatar
qvt408 is infamous around these parts
Same problem here, could never fill up to full without it clicking. I usually hold the pump upwards and it usually works.
Old Nov 23, 2010 | 07:15 PM
raineycd's Avatar
I think it is pretty common. Read it somewhere...
Old Nov 24, 2010 | 04:58 AM
jjc4scab's Avatar
Thanks for u replies guys.....I will let my friend know......seems crazy to pay to get it replaced, when it will just keep happening?????
Old Jan 16, 2011 | 03:50 AM
4G64T's Avatar
4G64T is infamous around these parts
Same thing happened to me today. Drove into the gas station with only half a tank left. Put the nozzle in and got half a gallon in before it overflowed. Kept taking the nozzle out and adding fuel. Did this 8 - 10 times but only got another half gallon. Any suggestion. This is a pain in the a**.
Old Jan 16, 2011 | 07:42 AM
wross996TT's Avatar
Go to this link. There are a host of potential issues listed, fuel filler is near the bottom.
Old Jan 16, 2011 | 09:10 AM
RudyTT's Avatar
RudyTT is a splendid one to beholdRudyTT is a splendid one to beholdRudyTT is a splendid one to beholdRudyTT is a splendid one to beholdRudyTT is a splendid one to beholdRudyTT is a splendid one to behold
The best solution that worked for me is to have the gas pump handle point at the 9 'o clock position instead of 6 'o clock position (downward) when filing up.
PV=nRT.
Sep 9, 2022 06:06 PM
DBB
Jan 7, 2016 09:32 AM
DetomasoGTS74
Sep 7, 2015 09:42 AM
