Anybody Used the OT-2 with 996tt?
Old Dec 12, 2010 | 05:44 PM
raineycd's Avatar
Wonder if anyone has used this iPhone device/app and what data points it will display (like afr, timing, etc) for our cars. Looks pretty interesting!
http://www.ot-2.com/index.html
Old Dec 13, 2010 | 01:25 PM
Mr Freefall's Avatar
Mr Freefall is infamous around these parts
Here is an email I have had with a company in the USA on the same subject. I have opted for the non WIFI cable (GoPoint GL1) for the moment and it is being shipped over to me, so I have not had time to test it.
Hope this helps
On Fri, December 10, 2010 11:23 am, Gary wrote:
Dear support.
I am trying to acertain if your sotware will read O2 sensor reading from
the Kiwi Wifi.
I have a porsche 996 turbo which does datalog and record O2 sensor
readings from the Lamda sensors on the car. If you read the email below, the Kiwi Wifi should read these detaila, but I am trying to find some software to display the AFR value on the iPhone platform
Many thanks
Gary
Hi Gary,
If the vehicle supports this data, and sends it over the OBD-II port,
DashCommand for iPhone will be able to read it with the Kiwi.
If you don't have a Kiwi yet, I would suggest getting something else. The
Kiwi is known for dropping connections often. I get more complaints about
the Kiwi than any other interface. I would suggest either the OBDLink WiFi
or the GoPoint GL1. If you've already got the Kiwi go ahead and try it
out, a lot of users use it without any problems.
OBDLink -
http://www.palmerperformance.com/store/product_info.php?cPath=25&products_id=52
GL1
- http://gopointtech.com/
Let me know what you think.
Regards,
Weston
Old Dec 13, 2010 | 02:20 PM
raineycd's Avatar
Awesome! Thank you for the info!!!
Old Dec 13, 2010 | 02:23 PM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
I have it and it works well....
Old Dec 13, 2010 | 02:27 PM
raineycd's Avatar
Cool! So you get the AFR / Lambda readings without any extra hardware?
Old Dec 13, 2010 | 02:53 PM
str8blst's Avatar
You will need the extra hardware to see the additional info like boost, afr etc. I just use it to clear codes and read extra info...
Old Dec 13, 2010 | 09:48 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
How does this compare to the Durametric?
Old Dec 15, 2010 | 11:53 AM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
i use just to clear codes as well, u can read RPM's and other little things without hooking up everything else (rest of the kit is for sale if anybody wants)
Old Dec 15, 2010 | 12:25 PM
raineycd's Avatar
Originally Posted by Eric@AMS
This is a great piece! We actually did a writeup for one not that long ago:
https://www.6speedonline.com/forums/...le-review.html
Hey Eric! I did see that write up, but was wanting to know for sure if it would display AFR using the 996tt built in wideband? I don't think it does by the responses so far... Would be a really nice thing if it did!
Old Dec 15, 2010 | 02:52 PM
Yeah, I believe you are correct. It does need its own secondary sensor.
Eric
Correct, you have to use the piggback Lamda sensor, then the inline module for this. I got hold of the European Sales manager and they confirmed this when I was looking at the unit.
At the beginning of this thread you will see the other hardware and software I have found. Once I get the cable here in the UK from the US I will let everyone know if it logs AFR's etc.
I cant get hold of a Brockway, so this will my portable route to log engine data while on the move, as Durametrics is not on the iPhone platform yet...
Gary
Old Dec 19, 2010 | 03:13 AM
As an update, I got the cable. I have just plugged it in for about 10 mins, and am using the http://www.palmerperformance.com/pro...mand/index.php software for the iPhone.
The software was £30, so about $50. Good news, it found all the fault codes, and displayed them the same as the Durametrics, and it does pick up the AFR value, and display your AFR Value, as an AFR value.
If you go here http://www.palmerperformance.com/downloads.php you can get the software for your PC.
Also on that page you will find the user setting and more importantly the CALC_PID reference table. Now reading into these if you look at the AFR table, it allows you to select the O2 sensor and which side.
When you first load the software then select the interface, it does automatically select the PID for you, but you can select alternatives if you need.
So, so far it look like a really nice piece of kit, I am using the GL1 cable, and once I get it all sorted out, I might buy the WIFI version from Palmer performance.
I have no affiliation with any of this, just someone that was looking for a Brockway and could not get one, so went in search for an alternative, and one that read AFR direct from the ECU. Do your own research before you buy I would say.
Gary
Old Dec 20, 2010 | 01:28 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
I got the Torque app ($4.95) on a Droid with the kiwi blue tooth interface ($99.95)and a windsheild mount. If you program the smaller size gauges it vibrates too much to see. The digital and graph read outs are easier to read than the gauge read outs. Very easy to pick the OBDII read outs you want to monitor. Decend data logging depending on the size memory chip in your phone. Don't expect all OBD read outs to work since all cars don't supply the same information. I'm thinking of going to a 7" andriod based tablet with a more fixed mounting point (like the empty single din slot below the nav). The bluetooth version of the Kiwi seems to work better than the wifi version if you wire your phone to an always on fuse holder.
Terminator
Oct 7, 2015 08:12 AM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
gjpearce
Sep 30, 2015 04:26 AM
Fullthrottleguy
Sep 28, 2015 03:19 PM
