vaccum leak test
Old Jan 21, 2011 | 10:46 AM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
vaccum leak test
How does one do a vaccum leak test?
Old Jan 22, 2011 | 06:33 AM
Tim941NYC's Avatar
Not to sure why you would do one. Are you trying to target one system that is after one of the multiple check valves? Or are you just checking what your motor is pulling at idle or part throttle?
Old Jan 22, 2011 | 06:54 AM
Saint Ari's Avatar
I'm getting maf psm lights ... And at times stalling when coming to a stop light ... Had a boost leak done ... And no leaks ... I figured I'll check for vac leaks before changing the throttle body ... Which is what they recommended ...
Old Jan 22, 2011 | 07:11 AM
Tim941NYC's Avatar
Try smoking the car right through the intake. the smoke will show more.
Old Jan 22, 2011 | 07:35 AM
bk doc's Avatar
bk doc is infamous around these parts
Seems like you East Coast guys'll smoke anything Tim.....lol
Old Jan 22, 2011 | 07:37 AM
Tim941NYC's Avatar
haha.. as this thread goes up in smoke!
Old Jan 22, 2011 | 01:04 PM
Saint Ari's Avatar
thanks guys!
Old Jan 22, 2011 | 07:59 PM
Tim941NYC's Avatar
I had to leave my car on the smoke machine for quite some time to find my leaks. Keep it on and start looking all over. The intercooler ducts, under the car, and under the front cowl. once thats square then run your 30-40psi boost test. hope this help you.
Old Jan 26, 2011 | 07:04 PM
tjj7ff's Avatar
tjj7ff is infamous around these parts
I had a similar problem,PSM and ABS lights going off and stalling at lights. The second phase on my alternator was bad.
BLKMGK
Sep 19, 2015 03:51 PM
MrMiggy
Sep 14, 2015 02:18 PM
rsdub
Sep 10, 2015 03:30 PM
sparks
Sep 8, 2015 03:03 PM
