installing GT2 top bumper vent on 996TT bumper?
Old Jan 24, 2011 | 08:26 PM
legendr34's Avatar
legendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud of
is this possible?
Old Jan 24, 2011 | 08:53 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
hard to do ona ureathane stock bumper alot easier with a fiberglass bumper.
i wont say impossible but it wont be cheap.
Old Jan 25, 2011 | 07:17 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
There is a GT3 front vent that fits. It is OEM and you can cut the stock 996tt front bumper and fit the GT3 vent. I can't find the pictures of who did this, but it was a C4S and a few years ago. It would be cheaper to buy a rep GT2 front end however.
Old Jan 25, 2011 | 08:24 AM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
That would be great, subscribed to hopefully see some pictures.
Old Jan 25, 2011 | 05:46 PM
DYL 911's Avatar
DYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to allDYL 911 is a name known to all
I can't believe this would be very difficult to integrate. Cutting is pretty straightforward as long as you are relatively precise. You will either need some heavy adhesive or create some kind of bracket to hold it.
Old Jan 25, 2011 | 06:19 PM
FLY996's Avatar
FLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud of
Not sure this will work without a lot of fabrication. As I recall, there are tabs for the bumper connection to the car in that area. Once you cut out that space there would not be enough tab connection for the bumper connection to the car. The 997 GT3 grill would work, but it does not line up with the 996 hood outline.
Probably better off locating a GT2 bumper
Old Jan 25, 2011 | 06:28 PM
Page's Avatar
Page is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of light
The factory GT2 vent is an insert, it's recessed in the bumper. You would have to cut a hole, mold in a cavity or some sort of support for it.
996 TechArt is also the same way.
You're better off aftermarket GT2 or factory GT2 bumper if you want the vent.
The 996 GT3RS has 3 curved rectangle openings with mesh screen covering the vents. You might want to look into this style.
The 997 GT3 vents actually sit on top of the bumper, so cutting a hole and putting one on is easier. This might work but the bumper shape is different and it contours the hood.
Old Jan 25, 2011 | 07:42 PM
legendr34's Avatar
appreciate the input everyone, it would nice get GT2 bumper, but I rather not go aftermarket and oem is too $$$
Old Jan 25, 2011 | 08:51 PM
gnewhouse's Avatar
gnewhouse has a spectacular aura aboutgnewhouse has a spectacular aura aboutgnewhouse has a spectacular aura about
997tt example
This 997tt Cabriolet has a GT3 grille in it... I believe the work was done by Lucent Motors in LA.
More pics at -
http://www.flickr.com/photos
Cannot speak to the differences between 997tt & 996tt in this regard, but the posts above appear to...
Old Jan 25, 2011 | 11:48 PM
LO_996tt's Avatar
LO_996tt is infamous around these parts
It seems like a drop in for 996tt would be a great after-market add. You would get the vent of a GT2 without a full bumper swap. I am surprised that there is not one out there. I would go for it. Cut a hole... 3m tape... drop it in and your done.
Old Jan 25, 2011 | 11:57 PM
legendr34's Avatar
i agree, i think it will look very nice and aggressive
Old Jan 26, 2011 | 08:54 AM
LiNks's Avatar
While your at it, make it in Carbon Fiber too!
Old Jan 26, 2011 | 12:45 PM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
Subscribed... however the gt2 is also functional. It has a vent intake underneath which redirects air across the bonnet area. Correct?
Old Jan 26, 2011 | 05:29 PM
legendr34's Avatar
i just emailed a carbon fiber fabricator about this, maybe they will take on this project on making a drop in Gt2 style vent for our cars, of course it will only be cosmetic
Mackchacha
Jul 9, 2019 11:03 AM
TrackOne
Aug 20, 2015 12:56 PM
Nissan GTR
Aug 19, 2015 02:11 PM
m_motorsport
Aug 19, 2015 03:34 AM
