Standalone or not to standalone
Old Sep 26, 2011 | 01:54 PM
  #76
kelesha's Avatar
kelesha is infamous around these partskelesha is infamous around these parts
Originally Posted by Tim941NYC
The DME preforms self tests and dumps extra fuel to see the secondary O'2 response time and delay to inputs plus reading value. That is why the simulators do not work and if you pull the O'2 to far out of the exhaust stream.
Absolute correct !!!
Your tune can be the holy grail of tunes but without cats your secondary O'2s will trigger a CEL. 997's are different DME's
Thats not correct at all. You can have O2 sensors and CAT emissions readiness test PASSED even without second O2 sensors connected, and thats without fault codes at all, its simple software work really, 996 or 997 car is not important, these functions are same on both ECUs
Problem is when on smoke check they put gas analyzer probe in exhaust.........if you run without CATs you cant pass that check at all, the only way is to put back CATs
Old May 31, 2012 | 09:03 AM
  #77
Tim941NYC's Avatar
Well after more and head scratching and seeing that no one else is getting the big 2150cc injectors to work with the 996 ecu plus the fact that the cams I am going to use only have a home tab and not the home plus 3 the factory uses. I am guessing my dash will be a Christmas tree. lol. I will get to cutting to valve pockets in my pistons soon I hope, not something I want to start and not have the time to finish. Then I can button up the motor and get some answers.
Old May 31, 2012 | 11:28 AM
  #78
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
The tuner is not the question rather what the members think about running a standalone.
Years back it was important to me to use the factory DME. Now I could careless. I am very interested in seeing what your build does.
Highlighted in red.
Most people here just do not get the logistics of it all and the ones that do will know why you are doing it. Really Tim I would not figure you for the type that would worry about the approval of the internet mass's.
Old May 31, 2012 | 11:36 AM
  #79
Originally Posted by Engine Guy
Highlighted in red.
Hahaha Timmy doesn't give a f@ck lol
#TeamAIM
Old May 31, 2012 | 11:54 AM
  #80
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
I think this would be an amazing solution for your dash:
Old May 31, 2012 | 01:50 PM
  #81
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Tim I've got a sweet dash panel from our old car laying around somewhere that replaces the factory cluster with a AIM unit. Takes care of the Christmas tree problem, just will a bit of programing by your tuner.
Old Jul 17, 2012 | 07:04 AM
  #82
Tim941NYC's Avatar
Update: After lots of head scratching and time limits to get to a event this year with the car I think Wes is right and that just drop the factory dash and running a after market dash is the way to go. Things that are forcing the change from the factory dash are the loss of the vario, the ecu just cant handle it..
Old Aug 28, 2012 | 09:30 PM
  #83
Tim941NYC's Avatar
Update.. I dropped the fly by wire for now, I have air temp, pre intercooler, post intercooler, water temp, oil temp, oil psi, lambda bank 1&2, fans, fuel pump, MAP, TPS, idle air stepper, crank trigger(factory), cam sync, fuel psi, and blood psi.
Old Aug 28, 2012 | 09:40 PM
  #84
Tim941NYC's Avatar
Old Aug 29, 2012 | 06:31 AM
  #85
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
No knock or egt's?
Old Aug 29, 2012 | 09:10 AM
  #86
JETmn's Avatar
JETmn is infamous around these partsJETmn is infamous around these parts
I have been a bit baffled why there isn't a better programming option than flashes also. I guess I got spoiled by other platforms that had better options in that area. Not being able to program on the fly with live feedback seems archaic to me :P It seems to work pretty well though and it seems Porsche put a lot of safeguards and a good ECU in the car.
Old Aug 29, 2012 | 05:20 PM
  #87
EBELLO's Avatar
EBELLO is a splendid one to beholdEBELLO is a splendid one to beholdEBELLO is a splendid one to beholdEBELLO is a splendid one to beholdEBELLO is a splendid one to beholdEBELLO is a splendid one to beholdEBELLO is a splendid one to behold
wish you the best hope you finish it soon, get it done for TI or TXmile.
Old Aug 29, 2012 | 05:33 PM
  #88
Tim941NYC's Avatar
Eddie you know how it goes.. My main business is so busy and the union is at full employment so I am force to turn away work.
Old Aug 29, 2012 | 05:34 PM
  #89
Tim941NYC's Avatar
Originally Posted by evil 996tt
No knock or egt's?
No knock. egt's
Old Aug 29, 2012 | 05:46 PM
  #90
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Tim...you get my pm?
