New Y-Pipe Design
Old Feb 6, 2011 | 10:43 PM
John@SpeedTech's Avatar
New Y-Pipe Design
We recently completed this new 2.5" x 75mm Y-Pipe design. It features extended length feed tubes and is suitable for either OEM intercoolers or larger aftermarket units.
This one includes optional mounts for meth injectors and satin black powder coating for a clean OEM look.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Feb 7, 2011 | 05:50 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
nice work John
Old Feb 7, 2011 | 05:37 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Sweeeeeeet!
Old Feb 7, 2011 | 08:46 PM
Thanks, guys - not only does it enhance air flow, it looks really nice installed, too. Much better in person than the pictures depict...
2022 Cayenne White
Old Feb 7, 2011 | 09:09 PM
kwei's Avatar
kwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud ofkwei has much to be proud of
Nice John, did you guys do the CF airbox too?
Old Feb 7, 2011 | 09:13 PM
Tim941NYC's Avatar
Looks good. Is there a bead rolled on the TB side, the stock setup locks in the grooves. Do you have a pic of the under side?
Thanks, Kwei. No, we purchased the CF air box cover...
2022 Cayenne White
Old Feb 7, 2011 | 09:54 PM
Hi Tim,
No, a groove/bead is not necessary when you upgrade to the 75mm TB. You have to use larger, smooth silicon hose vs. the OEM hose with the molded lip for the larger throttle body. Once installed, there is no way for the hose to move out of place due to the tight fit and with a good clamp, it seals perfectly with smooth silicon hose. The smooth hose also provides the ability to trim the hose length as necessary for better for/aft adjustability and final fit. There is really no need for the lip. Sorry, I do not have an underside picture at this time.
If you purchase a Y-Pipe for the OEM TB, then we machine a groove in like the OEM version, in order to re-use the OEM connector. However, hardly anyone that buys an upgraded Y-Pipe will stick with the OEM throttle body. We have only sold one or two like that...
Here is a picture of the machined lip for the OEM hose.
2022 Cayenne White
Old Feb 8, 2011 | 09:04 AM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
great work, what is the final price going to look like?
Old Feb 8, 2011 | 12:11 PM
HI Lennon,
Forum rules do not allow pricing in this area of the forum. I will PM you pricing, but I will say it came in under our previous version with the silicon hose legs.
John
2022 Cayenne White
Old Feb 8, 2011 | 12:29 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Looks very nice John. Great work.
Old Feb 8, 2011 | 05:55 PM
Thanks, Nikolas - If you ever decide to go further with your mods, give me a call and I'll help set you up as best I can...
2022 Cayenne White
Old Feb 8, 2011 | 06:02 PM
Nikolas's Avatar
I'm sure I will! Looking forward to the exhaust.
Old Feb 8, 2011 | 07:33 PM
Similar question.... but on the little small tubing... does the new version have the bead? Reason I ask is because I installed your older version for a client...
Im only suggesting that those2 tubes be cnc machined as well with a bead so the hoses do not fall off under higher boost....
nice work
mark
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 8, 2011 | 08:17 PM
Thanks Mark,
We have not put beads on the two smaller hose nipples, as we have never had one pop off at up to 1.4 bar. They are pretty long and create a lot of hose friction, along with a solid clamping area. A good idea though, it would add a degree of security and we can easily do it, so why not...
2022 Cayenne White
