Please help, need mod advice...
Hey gang, I have an 03 Turbo with X50 and EP Stg 2 exhaust as well as GIAC flasher, currently running on the 93 Pump tune.
What I would like to know is what mods should I look into next to get me into the 550-600 awhp mark?
Can I just do a boost controller of some sort (Greddy Profec etc.) or do I have to do something else to run more boost? i.e just different wastegates or???
Also I assume I have to do something with the fueling? What do you all suggest? Just throw in a 5bar and???
I've been doing alot of searching but cannot get the exact answer I'm looking for. Thanks in advance!
convert your k24a to 18s, upgrade to 1 bar springs, maybe injectors,and of course a tune...
markski
markski
2001 996TT 3.6L and stock ECU
do 18G rebuild, injectors, tune. you will need a clutch to, no a matter of IF, matter of WHEN
#TeamAIM
#TeamAIM
18g's will get you what you want with no sacrifices. Just need injectors (better than a 5bar), clutch and a tune. This will get you very close to 600 wheel. My times below are on 18g's, injectors, exhaust and a Meth kit all tuned by EPL.
what everyone else said: 18g, clutch, tune, *definitely injectors* as you will max a 5 bar. Handful of dead engines out there from 5 bars with 18gs. Talk to your tuner about the boost controller vs DME controlled. Nice to haves would be good intercoolers and inlet pipes. Also a durametric to be sure everything is happy.
Awesome! Thanks for the very helpful info guys.
Two more quick questions. If I do injectors do I need the 5 bar as well? Also what size injectors do I go with for the 18g's?
Talk to your tuner about injector sizes, some common ones for that power level are 58lb/hr and 72 lb/hr (assuming you want to run gasoline and not E85).
HI,NO question,the next step...Bang for the buck>>>K24/18g up grade and minimal the 5bar but should go with the injectors....And a tune to match that.Only bad part,GIAC does not make a tune for K24/18g's,so you have to get a new tune from another vendor and he will tell you what injecter size to run for his tune,,,But GIAC should hold a slight credit for you for the future since you did buy one from them originally.......Good Luck....
sdg1871
Dec 24, 2015 12:22 PM
