Dual in-tank fuel pumps, do you run an aftermarket fuel cooler?
Old May 28, 2011 | 04:10 PM
  #31
Tim941NYC's Avatar
I hear what you are saying, I ran a setup like you describe but what happened to me was one pump was failing... They don't always just stop pumping fuel when there dieing. Lets agree that It DOES work, it is a band aid and can fail resulting in engine damage. A single pump is no harder to install then the nice system you made for yourself there. BTW how are you priming the second pump? the fuel fill line spills in like stock one? separate returns for each and one return goes to each basket?
Old May 29, 2011 | 01:28 AM
  #32
Speedfreak's Avatar
Speedfreak has much to be proud ofSpeedfreak has much to be proud ofSpeedfreak has much to be proud ofSpeedfreak has much to be proud ofSpeedfreak has much to be proud ofSpeedfreak has much to be proud ofSpeedfreak has much to be proud ofSpeedfreak has much to be proud of
You are right, but it's no different then running a single pump, you will get the same result with a single pump starting to fail.
Priming is like stock, separate returns and they are crossed, meaning one pump fills the other basket.
Old Apr 11, 2015 | 12:14 PM
  #33
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
^I'm warming up to the idea.
The stock ECU does have independent control of each bank, with the necessary closed loop feedback to compensate/know when a single pump pump is failing right?
Another way to look at it, say one banks fuel system is just slightly off from the other in terms of fpr ramp and/or fuel pressure. The stock ECU again can handle this right?
Is there anything in the stock ECU's programming to expect balanced fuel delivery to both banks?
If all the above is okay, I think the dual pump, with each supporting 1 bank may work just fine.
Old Apr 11, 2015 | 03:17 PM
  #34
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Im running 2 Walboro 455's 1 to each rail and both rails thru one reg, I have a fuel pressure sender and my syvecs has trips so if it sees pressure fall below X for Y amount of boost it shuts down and goes into limp mode.
turkish1
Nov 11, 2015 09:01 PM
turbotuner20v
Sep 11, 2015 12:02 PM
tkebp1275
Aug 31, 2015 06:35 PM
orbelo
Aug 30, 2015 12:26 PM
The Oss
Aug 24, 2015 08:19 PM
