Dual in-tank fuel pumps, do you run an aftermarket fuel cooler?
Old Mar 7, 2011 | 01:53 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Just installed a dual 044 pump system in my car and was wondering if those who have the same setup (Evo guys) are running aftermarket fuel coolers? These pumps get pretty loud especially when they get hot. From what I have been reading most big fuel line kits bypass the factory cooler? Thoughts?
Old Mar 7, 2011 | 02:15 PM
Tim941NYC's Avatar
Thoughts? Loose the two pumps and get one that can do the job. Rebuilds are very expensive when one stops working, you will not know as one does enough for work for normal driving and short bursts.
Old Mar 7, 2011 | 02:34 PM
dgreen78's Avatar
? Can you tell me a single pump that is reliable that will fit in the stock basket? And dont say Aeromotive Blew a motor with one of those hunks of sh*t. Rebuilds?, the 044s are $200 brand new?
The 044 pumps have been proven to be VERY reliable. I have a fuel pressure gauge in the car that warns me if pressure gets low under boost.
-Don
Old Mar 7, 2011 | 03:57 PM
Tim941NYC's Avatar
I do not know of one pump that will fit in the stock basket that will handle that power. Its like everything else on these cars, redesign something that will do what you need. I am running one weldon that's good for 2500 hp.
Old Mar 7, 2011 | 03:59 PM
dgreen78's Avatar
Can you post some pics of how you did it? Are you using the stock pump as a lift and the Weldon externally??
Old Mar 7, 2011 | 04:05 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
No fuel cooler here, or on any of the other similar builds that I know of...
Old Mar 8, 2011 | 10:48 AM
SamboTT@ByDesign's Avatar
What's up Don...Subscribed
Old Mar 14, 2011 | 10:46 AM
dgreen78's Avatar
Talked to Todd at Protomotive today and he said you must run some sort of cooler or the fuel/tank will overheat. He said he has seen drops in fuel pressure if the factory cooler is not tied into the system. I am now trying to figure out an aftermarket cooler or splitting the return so half is going into the factory cooler.
Old Mar 14, 2011 | 01:30 PM
jags911tt's Avatar
jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !jags911tt Is a GOD !
Keep me updated on this bruv
Jag
Old Mar 14, 2011 | 01:35 PM
dgreen78's Avatar
I have ordered up a fuel cooler normally found on a diesel truck. This is the longest I could find. Hopefully it will fit in the tunnel next to the d-shaft. They make a single pass -6AN in/out. This "should" do the trick I hope. Will keep ya posted. Best part it was only $75! No p-tax
Old Mar 14, 2011 | 01:40 PM
jags911tt's Avatar
Do you have the same fuel system as me? Is Alex installing the fuel cooler for you?
Jag
Old Mar 14, 2011 | 01:47 PM
dgreen78's Avatar
Jag
Yea, pretty much the same thing. I havent talked to Alex about it yet. I will probably throw it in myself.
Old Mar 14, 2011 | 07:10 PM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
I have two 044 pumps and they to get really loud when fuel gets hot, pumps began to cavitate. Im also trying to figure a solution. It usually happens about half and hourr after driving which sucks *****. Keep you guys posted if a resolutions comes up.
Old Mar 15, 2011 | 02:16 AM
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Subscribed!
Old Mar 15, 2011 | 06:44 AM
Tim941NYC's Avatar
If you put your fpr by the tank you will not heat the fuel by passing it over the hot motor.
