Gas station gas
Old Mar 9, 2011 | 06:46 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Gas station gas
I have tried almost all the gas stations in my area and so far the only one I can trust for max boost ( 1 bar ) is marathon 93 oct. I can't tell any difference from 106 oct, which is also available at my local marathon station. Anyone notice anything similar or different.
Old Mar 9, 2011 | 07:35 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Pat,
What are you expecting as far as differences between the two on a stock tune?
Old Mar 9, 2011 | 08:18 PM
pat's Avatar
pat
Wasent sure if there would be any difference. Sometimes tuning can adjust timing and boost up to were knocking ocures. Slight knocking is ok hard knocking is bad.
Old Mar 9, 2011 | 09:20 PM
If you are still on a stock tune and have no adjustable boost controller, you won't feel a difference in power by using higher octane fuel.
Old Mar 9, 2011 | 09:31 PM
996PCarGo's Avatar
996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold996PCarGo is a splendid one to behold
Arrow +1...
This...
Old Mar 9, 2011 | 11:46 PM
ard's Avatar
ard
I disagree.
Adding 100 or 106 to a tank of 91, 93 will bring the mixture up to the octane so that the engine will not be pulling timing.
While it is true you will not get the full benefits without a specific tune, the factory tune is optimize for the fuel of around 96-98 octane as measured (R+M)/2.
And "boost gauge readings" as a performance indicator are ill conceived IMO. You will see changes in timing advance not boost necessarily.
Finally it is absolutely false that an external boost controller is needed to see improvement with with increased octane fuel!
Old Mar 10, 2011 | 12:39 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by ard
I disagree.
Actually, the recommended (R+M)/2 is 93. 98 is the recommended RON rating which is why he might not be noticing any difference.
Old Mar 10, 2011 | 05:40 AM
pat's Avatar
pat
I must have a tune because I see a solid 1 bar boost. I do not have any info on who's tune it is. The car came that way.
Old Mar 10, 2011 | 10:06 AM
Ard, if you read my comment, I said, "feel" the difference by using the higher octane fuel. You may "see" timing differences in a data log, but at 1 bar on stock 16's you won't feel any more power. And this is what the OP stated already.
OF course you don't need a boost controller to add more power when a tune can handle that.
I disagree.
Old Mar 10, 2011 | 04:51 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
my giac allows me to change to race file with 100 oct gas. it's a REAL big difference really!!! ofcourse reg pump gas is 91 here in commie cal
Old Mar 10, 2011 | 04:59 PM
pat's Avatar
pat
What system do you have that let's you switch like that.
Old Dec 12, 2018 | 07:36 PM
Svx's Avatar
Svx
Svx is infamous around these parts
The Aston is thirsty...
White991TT
Mar 8, 2016 06:01 AM
sdg1871
Nov 22, 2015 07:27 PM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
whtrabt
Oct 5, 2015 05:23 PM
TOGWT
Detailing
Oct 1, 2015 07:59 AM
