big thanks to epl...getting my car back soon...725 hp
details?
#TeamAIM
#TeamAIM
As far as I know EPL uses a load bearing mustang dyno which calculates the crank numbers after the pull is done by letting the wheel come to a stop. In this case its not really an estimate...
#TeamAIM
#TeamAIM
Spot on... good math skillzz
. 589 I believe was the high pull with 600+ ftlbs.
I know there has been discussion lately what the limit of the stock fuel pump is.... This is 100% the limit of a good working stock fuel pump.
Specs
Alpha 3076's with billet wheels (1.3 bar)
93 oct pump fuel... NO METH
USP Inlets (very nice piece!)
Europipe exhaust
72lb injectors
Custom EPL Tune
AWE IC's and silicone hoses
Ill post some dyno plots shortly.
. 589 I believe was the high pull with 600+ ftlbs.I know there has been discussion lately what the limit of the stock fuel pump is.... This is 100% the limit of a good working stock fuel pump.
Specs
Europipe exhaust
72lb injectors
Custom EPL Tune
I have no knowledge if he does coast-down testing, and there is some debate on the validity of that, too.
Unless it is measured at the flywheel, it is still an estimate.
Very few discussions are had about flywheel numbers because very few tests are done in that matter and very little actual test data to back up drivetrain loss %'s.
589whp is what matters and can be used for comparison to other cars.
Nice results, BTW!
on that dyno 590whp is very impressive just using straight pump fuel
#TeamAIM
#TeamAIM
