Clutch Kit
Old 05-20-2011, 09:14 AM
reddswiss's Avatar
reddswiss has a spectacular aura aboutreddswiss has a spectacular aura about
Clutch Kit
I found this sport clutch kit from Sachs. Is anyone using or familiar with this kit?
Sorry about the pic size.
Thanks in advance.
Old 05-20-2011, 09:21 AM
Tim941NYC's Avatar
Very hard to read. If you are keeping the dual mass flywheel then I would use the gt2 disc ( un sprung) and a 999 pressure plate. The un sprung disc is lighter and will be much easier on your syncros. Also this set up will work for you with all bolt on mods until you up grade fuel injectors.
Old 05-20-2011, 09:38 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
subscribe
Old 05-20-2011, 09:40 AM
reddswiss's Avatar
Sorry about the size. I will have an independent install if this is a good option. Single Mass -
I spoke with Cargraphic, this is what is available. It's hard to get anyone here to install anything other than car specific OEM parts
http://www.cargraphic.com/index.php?/s,6,7,18,717,1287,1057/&start=6Single mass Sport
clutch kit / Single Mass
Price: 2.500,00 EUR /5
Old 05-20-2011, 09:53 AM
Tim941NYC's Avatar
When I look at the link it states "single mass kit" but does not state if the fly wheel is included. Even if it is 2500 EUR is heavy!
Old 05-20-2011, 10:26 AM
reddswiss's Avatar
Europe is expensive! Kit includes LWSMFW
Old 05-20-2011, 10:41 AM
Tim941NYC's Avatar
If it is the lwsmfw then you will need the throw out bearing with the longer ears (think 944 part) and the sleeve that the throw out bearing rides on, neither in pic. If so then that seems to be the same setup that UMW sells. I am not sure what it is like to import parts but you can save a lot of money. PM in bound!
Old 05-20-2011, 05:04 PM
VAGscum's Avatar
2nd.
The GT2 clutch kit is just a 996TT clutch with an un-sprung disk. No increase in torque capabilities.
Old 05-20-2011, 05:10 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Hey buddy, you can get the clutch disc and pressure plate from Sachs racing itself at about 1K, and buy a RS flywheel + all the bolts/bearings etc from a Porsche dealer for under 1K.
Total less than 2K €.
These are the parts you need if you use the rs flywheel
931-102-111-00 BALL BEARING
928-102-151-01 SOCKET SCREW
944-116-080-01 RELEASE BEAR
950-116-813-30 CLUTCH GUIDE
964-102-239-31 FLYWHEEL
964-114-143-31 RING GEAR
N-014-715-3 SCKT SCREW
Old 05-20-2011, 09:57 PM
johnspeed's Avatar
HI,,There are 2 different 999 pressure plates....One has more clamping force then the other....There was a recent thread on this.....Also Sachs has a higher performance GT2 disc with special lining over stock one which has more holding power.....Good Luck
04-28-2022 12:38 AM
orbelo
08-30-2015 12:26 PM
The Oss
08-24-2015 08:19 PM
Quick Reply: Clutch Kit
