Kw v3 installed but.....
Old Jun 1, 2011 | 08:05 PM
JFC's Avatar
JFC
JFC is infamous around these parts
got my kw v3 installed + CG strut brace. it doesnt feel bumpy on rough road and cornering is stiff, the car body-roll feel much solid. the only problem i have is when i do turns in the carpark (super slow speed) or turn steering about couple inches left right with car still i can hear the "CLUNK". Is it normal? the sound only come in slow speed "no noise when i go thru bumps".
pls help
Old Jun 2, 2011 | 12:25 AM
ard's Avatar
ard
Not normal. Bring it back to whomever installed the KW
Old Jun 2, 2011 | 01:27 AM
legendr34's Avatar
legendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud oflegendr34 has much to be proud of
i had the same issue with my H&R coilovers and i discovered that the nuts that held the end links were not tight, after tightening, no more noise.
Old Jun 2, 2011 | 04:29 AM
landjet's Avatar
Make sure your lower control arm is not making contact with your sway bar.
Old Jun 2, 2011 | 04:50 AM
heavychevy's Avatar
What kind of droplinks do you have?
Old Jun 2, 2011 | 05:11 AM
TTS's Avatar
TTS
TTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of lightTTS is a glorious beacon of light
Check your sway bars are not hitting the drive shaft or control arms which may occur because of the lowering in height. Adjustable drop links may help by moving the arb out of the way. Same problem on mine as well.
Old Jun 3, 2011 | 04:21 AM
JFC's Avatar
JFC
got my shop checked.....the nuts are all tightened. Checked the spring as well, everything are fine~ but whenever i steer left to right or right to left the "CLONK" sound still there. He said prob is the Piston Rod problem.....but i do not have any problem while driving.
Old Jun 3, 2011 | 09:32 AM
ard's Avatar
ard
Did he say why the piston rod problem is only when you turn?????????
Old Jun 3, 2011 | 09:34 AM
ogomez79's Avatar
ogomez79 is infamous around these parts
Sounds odd to me. I had a clunk when turning but it was when my pillow ball bushings were shot (30k miles on them).
Old Jun 3, 2011 | 09:39 AM
Sharp's Avatar
Sharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud of
It's either a loose tie rod end or some loose sway bar links, and possibly even a loose upper strut mount....all need to be checked, the piston in the shock will not move at all when the car is sitting still. It needs to be check immediately, not safe to drive like that!
Old Jun 3, 2011 | 09:43 AM
Sharp's Avatar
in his case it may be loose upper strut mount....
Old Jun 3, 2011 | 10:54 AM
jspporsche's Avatar
jspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond repute
Does the KW have an adjustable strut bar mount? If so, it might be loose and rotating when you turn. This will eventually lead to end link failure.
If you have any pictures of the KWs installed without the tire in the way it would be helpful.
Jim
Old Jun 3, 2011 | 10:55 AM
jspporsche's Avatar
Oh yeah, you might want to call KW, they probably have a lot more expertise than us goobers.
Jim
Old Jun 11, 2011 | 09:11 AM
JFC's Avatar
JFC
Finally got it fixed ....may i know what height you guys using? my front is around 2 fingers from fender to tire...rear less then half a finger.
I am getting some knocking sound when going through some rough road.
Old Jun 11, 2011 | 09:47 AM
jspporsche's Avatar
Check sway bar end links. Get the car corner balanced. You want to do your best to use ride height to have the weight of the car sit evenly on all the tires. You probably won't get 50/50 but with that tire gap info, you have too much weight on the rear of the car. While this will help rear wheel traction, it really compromises the ability of the car to get weight over the front tires on braking and your stopping distances will go way up along with brake wear and heat.
Jim
