Importance of boost leak test
Old Jun 9, 2011 | 10:38 PM
Originally Posted by pumalex
Where do you guys get your adaptors to test? Not the wastegate but the whole system i mean. Do you do it at the turbo inlet or do you just take out the air box and do it from there?
We make them.... we do it at the turbo.... you block one off and pressure test the other....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 10, 2011 | 04:43 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
wouldn't it be better at the filter since you can test the inlet tubes also, everything after the MAF?
Old Jun 10, 2011 | 06:18 AM
raineycd's Avatar
That might be better, but that side is not normally pressurized and may not be made to handle the stress of extra pressure...
I went to Lowes and got all my supplies to block off one turbo and then pressurize the other. Pretty easy and cheap insurance!
https://www.6speedonline.com/forums/...ig-w-pics.html
I used that DIY, but on the one side you block off, I found a closed end rubber hose end so I didn't have to clamp on the extra pvc end!
Old Jun 16, 2011 | 10:55 AM
dragonman4's Avatar
dragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond repute
FYI for anyone looking to get a Mityvac, just randomly saw on amazon today while looking at motul brake fluid it's on sale for $29.59
Old Jun 18, 2011 | 04:52 PM
pwarnery's Avatar
pwarnery is infamous around these parts
Good advice!
Went to the garage today and pressure checked the wastegates. Sure enough, the driver side is leaking...I also checked the actuating pressure to see if they both opened at the same psi. The gage on my compressor lacks definition, but they seemed to open around 15psi. I need to double check these #s with a better gage. I guess I need to replace the wastegates now. But what should I buy? Stock, 1 bar? The engine has a RUF 520 engine kit with K16 based turbos. Any advice would be great. Also, what does a leaky waste gate does to engine performance or reliability for that matter? I have some Durametric logs I can post if this would be helpful. Thanks.
Old Jun 19, 2011 | 07:46 PM
RFFG's Avatar
RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !RFFG Is a GOD !
good info
Old Jun 20, 2011 | 10:30 AM
pwarnery's Avatar
After I found the driver side wastegate leaking at the seem of the capsule, similar location to the picture posted by Markski, I had a well respected tuner take a look at some Durametric logs, and this "leak" is not affecting the engine whatsoever. That is good news. So at least in my case I will leave that wastegate alone and not replace it. From a visual stand point when the compressed air was applied to the capsule, the rod would retract and slowly close back as the air escaped from the capsule. I welcome any feed back.
Old Jun 20, 2011 | 11:08 PM
I would replace it... would not even think twice about it...
9.66
click to view
Old Oct 10, 2013 | 04:05 PM
NTIMD8's Avatar
NTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond reputeNTIMD8 has a reputation beyond repute
I did a leak test on my car and it would hold pressure for more than a couple of seconds. After lots of searching I found this...
Would this result in a large loss of power even if I am still seeing 1bar on the gauge?
Old Oct 10, 2013 | 04:19 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
wastegate rod seal? I have the same issue on mine
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
cdrik915
New Member Introductions
May 14, 2019 11:15 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
