Importance of boost leak test
Old Jun 7, 2011 | 11:32 PM
I often preach about pressure testing the car from the turbos... and while there check the compressor wheel and maybe the wgs... do they open at the same time etc...
So today a 6speed member dropped off his K16s which I was about to do the billet wheel upgrade but before I took them in I decided to put a Mytivac gauge on the actuator... see where they crack open... then I found this.... a leaking Wg... and he had no idea...
Invest in a $100 pressure test kit you guys.... drop the car off at a local shop that has a big compressor... get it tested once a year- at least... trust me...
Markski
click here for a detail tutorial on tackling your 996TT boost leaks
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jun 7, 2011 | 11:50 PM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
Old Jun 8, 2011 | 12:27 AM
Turbo Fanatic's Avatar
Even if no leak you can equalize perfectly both wastegates so one is not lazier than the other.
A BIT off Topic Markski, but has anyone tried running a smaller turbo on one side and a bigger one on the other? May be silly but that may help spool and big end power?
Old Jun 8, 2011 | 02:26 AM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Originally Posted by tonka858
I find this sucker way more reliable
I got both...but than I own most of items from Harbor Freight
http://www.harborfreight.com/brake-b...kit-92474.html
Old Jun 8, 2011 | 01:27 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
This is a must even with brand new turbos. I was surprised to find my Tial Alphas were not even close to being equal crack pressure. Spool up was much better after finding this out.
Old Jun 8, 2011 | 01:35 PM
emadelta86's Avatar
emadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond reputeemadelta86 has a reputation beyond repute
Even though I got mine used, the left one was opening at 0.8 bar and the right one at 1.0bar...
Old Jun 8, 2011 | 03:50 PM
raineycd's Avatar
I am pressure testing my car right now after a clutch install and injectors. Initial test was no leaks, but then a vac hose popped off under the Y pipe. Cleaned it and zip tied it and will reinstall the Y pipe and test again! Not only will you find leaks, but weak connections as well!
That is crazy the WGs were leaking like that!
Old Jun 8, 2011 | 07:36 PM
I noticed that too.. I called Jake and let him know...
9.66
click to view
Old Jun 8, 2011 | 08:32 PM
Fastfrank's Avatar
Fastfrank is infamous around these parts
How do you know what each side is boosting seperately?
Old Jun 9, 2011 | 02:52 AM
emadelta86's Avatar
You test them with a manual pump, attahed to the needle on the WG's. Pump slowly and see at what pressure they crack open.
Old Jun 9, 2011 | 09:02 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
subscribe
Old Jun 9, 2011 | 09:09 AM
Tj Hunter's Avatar
Tj Hunter is infamous around these parts
911 TT telepathy???
Old Jun 9, 2011 | 09:18 AM
rdss's Avatar
Originally Posted by Tj Hunter
911 TT telepathy???
Old Jun 9, 2011 | 03:33 PM
Tim941NYC's Avatar
The larger the difference the wg opens the greater chance you can stall the turbo on the open gate. I was thinking about running a equalizer line say 3/4'' right before the turbo or wastegate (on external gates) to make sure both turbos see the same back psi.
Old Jun 9, 2011 | 05:36 PM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
Where do you guys get your adaptors to test? Not the wastegate but the whole system i mean. Do you do it at the turbo inlet or do you just take out the air box and do it from there?
