Locked out of gas tank!
Old Jun 14, 2011 | 05:08 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
So I went on a trip and left my keys at parents house. Ended up getting dropped back to my house where I only have a spare key that does not remotely lock/unlock. I can drive the car since I can manually unlock with the key. Problem is I can't unlock the gas tank since the manual unlocking of the door doesn't open the pin which is holding the gas tank closed. Other than driving over to get the key that works, is there a manual unlock for our gas tank covers?
David
Old Jun 14, 2011 | 05:17 PM
jakeskiny's Avatar
jakeskiny is infamous around these parts
Open the passenger door... at the top of the door jam under the A pillar, there is a circular ring... pull it straight out about an inch and that should unlock your gas cap cover.
This is also outlined in your owner's manual if you have it around.
Hope that helps.
kosmo96's Avatar
kosmo96 is infamous around these parts
Open your passenger door and at the top of the jam up underneath the top of the right front fender is a circular pull on a wire. It is the opener for the gas door in situations like yours.
Old Jun 14, 2011 | 05:18 PM
SSMugen's Avatar
I found it! there is a pull wire hidden toward the top of the passenger door.
Thanks--
Np---
Close thread! lol
SSMugen's Avatar
Hope that helps.
Thanks your quick! I ran out and then found your response!
Old Jun 14, 2011 | 05:19 PM
SSMugen's Avatar
Thanks! I got it!
Old Jun 14, 2011 | 07:32 PM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
I wonder whether the lock/unlock button in the car (on the dash) would work too?
Old Jun 14, 2011 | 07:37 PM
jakeskiny's Avatar
That lock/unlock button on the dash doesn't open my gas cap cover... I try that every time. One of these days, I'm going to pay the $300 and just fix my key fob.
Old Jun 14, 2011 | 09:21 PM
Aerodude's Avatar
OK -- just an idea. I actually have the opposite issue -- the gas cap doesn't always lock because the locking pin probably needs to be replaced. Not really an issue so I haven't bothered with it.
PV=nRT.
Sep 9, 2022 06:06 PM
pwdrhound
Sep 13, 2016 10:44 AM
Lucid Moment
Sep 12, 2015 01:12 PM
