Scary moment with the Maxjax!!!!!!
Old 07-13-2011, 08:38 AM
jpflip's Avatar
New fix but another problem....
I've receive the new fittings. Better quality, stronger spring and made by Dixon. Note: this new modification provided you with only two quick disconnect fittings and the attachments on the flow divider are now fix!
But I am facing another problem. After the installation of the new fittings on the flow divider, I discover a crack on the body of the valve. I immediately contacted Danmar and within 3 hours received a phone call from a nice gentleman, Gabe (the same one that call me for the fittings failure) and he is sending me a new valve. The over torque fittings possibilities cannot be a factor in the cracked body according to the Danmar rep.
The after sale service is pretty good but I'm still waiting to get a good working tool ;-) Hope yours are working fine, J.P.
Old 10-24-2011, 10:47 AM
iSaad's Avatar
iSaad is on a distinguished road
Glad to hear they were helpful! I have a leak coming from my body and the place where the hose attaches to the body. I replaced the teflon tape and still get leaks... I will call them soon.
Attachment 161291
Attachment 161292
Attachment 161293
Old 10-24-2011, 11:13 AM
jpflip's Avatar
Hard to say where it is coming from. May be coming from the junction of the body. Anyway don't forget to submit those pictures when you contact the service department. I hope you will get good result with the them.
Old 10-24-2011, 12:02 PM
Tim941NYC's Avatar
Do not use teflon tape on oil.. Use a sealant meant for oil..
Old 11-17-2011, 08:32 AM
iSaad's Avatar
Where's the best place to purchase the 90 Deg angle adapters and hose? I was thinking of wall mounting my power unit and running one side up and over the lift area to the wall... do you think this would cause any issues having one hose longer then the other?
Old 11-17-2011, 09:13 AM
jpflip's Avatar
On Rennlist , may be....
You will found some very good info about that kind of modification and where to get the fittings on Rennlist. I would like to post the link but I cannot, Go on Rennlist.com, select web forum, select 928 and do a search for ,MaxJax arrived today. You will get valuable information from MartyP and DrBob,with tons of pictures and place to get fittings in USA. Good luck, J.P.
They also discuss the issue with longer hose and NO you will not get any problem!
Old 11-17-2011, 09:42 AM
iSaad's Avatar
AMAZING! Thanks for the help.. I was able to find his post easily with the provided information by you.. read through it and had some good information in there.. I still have yet to send the email to MAXJAXabout the 2 parts that are leaking.. I'll try and get on that this weekend... so busy at work and when I get home I don't feel like dealing it it... but I need to the leaking is starting to annoy me....
Old 11-17-2011, 09:51 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
JP always helping,knows much....good friend
Old 11-17-2011, 11:41 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
+10 J-P is "L'Homme"
Old 11-17-2011, 03:51 PM
jpflip's Avatar
It would be difficult to continue to live a Porsche life without each other gentleman. Lets have a group hug!!!!
Old 12-02-2011, 08:57 AM
iSaad's Avatar
jpflip, do you use your 3" adapters which came with the MaxJax? If not, would you sell them to me? I called Danmar and they wanted $100 for them... figure most people are too low to use them so I was going ping people i've spoken with to see if they use them or don't need them... let me know! Thanks!
Old 12-02-2011, 09:12 AM
jpflip's Avatar
Sorry Isaad but I was not going to use them until my daughter bought a Scion XB. Now I need them for oil change... Good luck with your research!
Do not forget to go on Rennlist for your research especially here: http://forums.rennlist.com/rennforum...ved-today.html
dr bit
10-12-2015 09:05 AM
007 Vantage
10-08-2015 08:35 PM
DYL 911
10-01-2015 02:47 PM
Fullthrottleguy
09-28-2015 03:19 PM
Quick Reply: Scary moment with the Maxjax!!!!!!
