So Today
Old Jul 10, 2011 | 08:42 AM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
So Today
So Today whilst accelerating onto a highway, my transmission just died, got an engine check light coasted to a stop and then restarted the engine, car was ok. Got home, disconnected the battery and everything is fine again, normal oil and water temps, no leaks or mechanical sounds, CEL disappeared on battery reconnect, any thoughts on this rather concerning experience ??
Old Jul 10, 2011 | 08:59 AM
quick's Avatar
quick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant future
Sounds more like an electrical issue ? Similar thing happened to me couple of years ago in my C2 Turbo. We were able to traced it to one of the electrical onnectors that was just hanging in there.
Old Jul 10, 2011 | 09:34 AM
djantlive's Avatar
what do u mean transmission just died? do you have manual, pdk or tiptronic?
Old Jul 10, 2011 | 10:00 AM
RCH's Avatar
RCH
Tip, just lost all drive power, yes I think its likely electrical too
Old Jul 10, 2011 | 09:24 PM
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
Ignition switch? I was unable to shift past third in my tip when my ignition switch went bad, on top of lots of other random electrical issues.
Old Jul 10, 2011 | 10:54 PM
Maf.....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 11, 2011 | 09:36 AM
RCH's Avatar
RCH
thanks guys but when there is a MAF alert don't all the PSM lights etc come on ?
Old Jul 11, 2011 | 09:48 AM
unvmy996's Avatar
Not always .
Old Jul 11, 2011 | 11:12 AM
RCH's Avatar
RCH
Is it possible to flow too much air into the air filter as I have recently opened up the top of my airbox (which has OEM filter) or just likely I have a faulty MAF ?
Old Jul 11, 2011 | 12:26 PM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Have Durametric, got fault codes?
Old Jul 11, 2011 | 06:54 PM
porscheforfun's Avatar
porscheforfun is infamous around these parts
What a strange symptom lost after 3rd gear?
Old Jul 11, 2011 | 07:30 PM
say it outright what you just recently did first... then let the board answer....
I now even more so believe it's your maf...
invest in a Durametric... look for codes.. end of story...
you can disconnect the harness on maf... run the car at idle.. see if the car blips after you do it... while the car is running... if not then its your maf... if yes ( the rpms change) then your maf is probably fine...
simple fast way of diagnosing the maf... OR just go to the dealer and spend $600 and get it replaced...
9.66
click to view
Old Jul 12, 2011 | 05:08 AM
RCH's Avatar
RCH
Yes have got a Durametric now, lets see what I says, will it still report the code/s even though I have removed them via a battery reset, I have a spare MAF as well if it is that
Old Jul 12, 2011 | 01:48 PM
rob.boost's Avatar
rob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond reputerob.boost has a reputation beyond repute
Sounds like Karma
Old Jul 12, 2011 | 03:54 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Originally Posted by rob.boost
Sounds like Karma
ModBargains
997 Vendor Classifieds
Oct 13, 2015 03:53 PM
ModBargains
Ferrari Vendor Classifieds
Oct 13, 2015 03:47 PM
ModBargains
Oct 13, 2015 03:45 PM
vchris
Cayenne Turbo
Sep 11, 2015 02:52 PM
Compukidd
Sep 11, 2015 07:56 AM
